Jetson Xavier NX Developer Kit will not start
My apologies, I have now connected it to the J14 RXTX pins and gotten some output. It seems to keep running non stop but here is what I got.
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet leve        l 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.058] I> rst_source : 0xb
[0000.061] I> rst_level : 0x1
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.071] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] E> LOADER: Failed to verify SMD.
[0000.089] I> Primary SMD copy is invalid, try with secondary copy..
[0000.095] E> LOADER: Failed to verify SMD.
[0000.099] E> LOADER: Failed to verify SMD & SMD_b.
[0000.103] E> Error: SMD: Load failed
[0000.107] E> Load SMD failed
[0000.109] E> LOADER: Failed to get slot for boot chain from SMD.
[0000.115] E> LOADER: Failed to get storage info for binary 0 from loader.
[0000.121] E> LOADER: Failed to get info for binary 0 from loader.
[0000.127] C> LOADER: Could not read binary 0.
[0000.131] C> Fail to load mb1-bct bin
[0000.134] E> Task 24 failed (err: 0x1d1d1318)
[0000.138] E> Top caller module: LOADER, error module: LOADER, reason: 0x18, aux        _info: 0x13
[0000.146] I> MB1(1.5.1.6-t194-41334769-1740dd39) BIT boot status dump :
00000000000111111111101110000000000000000000000000000000000000000000000000000000        00000000000000000000000000000000000000000000000000000000000000000000000000000000        00000000000000000000000000000000000000000000000000000000000000000000000000000000        0000000000000000
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.138] E> Top caller module: LOADER, error module: LOADER, reason: 0x18, aux_info: 0x13
0000000000011111111110111000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
