Is there a drawing or document that specifies the plating of the SODIMM edge fingers on the Jetson Xavier NX module?
JEDEC MO-310C only provides recommended plating options in note 11 for SODIMM 260 pin modules. I am also not able to find a reference that states Jetson Xavier NX actually follows one of these recommendations.
The datasheet does refer to connector insertion reliability based on EIA-364.
However, I am looking for the actual plating specification.
