I am attempting to install Jetson 4.5 onto my Jetson AGX Xavier Dev Kit however when I get to the point where I need to install the SDK I run into apt issues.
I have added [trusted=yes] to the apt sources entries for the Nvidia repositories and that solved the majority of my initial issues, however I still get the following errors:
E: Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r32.5/main/binary-arm64/Packages Could not handshake: Error in the pull function. [IP: 23.54.159.184 443]
E: Failed to fetch https://repo.download.nvidia.com/jetson/t194/dists/r32.5/main/binary-arm64/Packages Could not handshake: Error in the pull function. [IP: 23.54.159.184 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
And this causes the SDK installation phase in the SDK mangaer to still fail. I have searched through some of the other issues raised around the repositories however none of them have ever mentioned this specific Could not handshake issue. I am able to update from the Ubuntu and majority of the other Nvidia repositories without issue so I dont think it is an issue my end.
Anyone else seeing this and know how to fix it?
I guess you cannot find similar toic because this repository only exists on jetson device but not the host side.
What is your method to run sdkmanager? What is your enivronment?
And is this issue on AGX Xavier or on NX? You filed topic on NX forum but you said it is AGX Xavier.
I am not having this issue on the host side, I am having the issue when the SDK manager tries to install the SDK items onto the Xavier using the installation scripts.
I am running the SDK Manager on a dedicated Ubuntu 18.04 desktop machine with the AGX Xavier connected via USB and to the same network.
This issue is for the AGX Xavier. I typed in Xavier into the topic field when creating this issue but the NX was the only one to come up.
To summarise:
I am running the latest version of the SDK Manager on a dedicated Ubuntu 18.04 host with the AGX Xavier connected to the same network and via USB to the host machine. The first stage of installing the image to the Xavier works fine, however the next stage of running the installation scripts to install the development tools onto the Xavier does not work, and results in the error I mentioned before causing the setup process to fail.
Are you talking about you are installing sdk like cuda, cudnn, tensorrt…etc from your x86_64 host to your xavier with micro usb connection?
I think it is using SSH. I have flashed the image to the Xavier over USB and it has booted and I can log in. I then need to find the IP address for the Xavier, and enter it into the SDK Manager. The SDK Manager then proceeds to transfer some scripts across to the Xavier and tries to run them to set up the additional tools, however it is at this point I get the apt update errors I mentioned.
Just want to know. Does your xavier have ethernet cable connected?
These two source lists are on the xavier but not the host side. Thus, it looks like the log you pasted is from the xavier side. What would happen if you type apt-get update command on your xavier? Will you see this error too?
Yes, it has an ethernet cable connected and that error log is actually the one that I copied from attempting to run an apt update manually on the Xavier. It happens both when the SDK Manager tries to install the SDK components and when I run apt update manually.
For completeness, when I first log into the Xavier and run apt update this is the output:
dev@Xavier:~$ sudo apt update
[sudo] password for dev:
Get:1 http://ports.ubuntu.com/ubuntu-ports bionic InRelease [242 kB]
Ign:2 https://repo.download.nvidia.com/jetson/common r32.5 InRelease
Get:3 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88.7 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease [74.6 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88.7 kB]
Ign:6 https://repo.download.nvidia.com/jetson/t194 r32.5 InRelease
Get:7 http://ports.ubuntu.com/ubuntu-ports bionic/main arm64 Packages [975 kB]
Err:8 https://repo.download.nvidia.com/jetson/common r32.5 Release
Could not handshake: Error in the pull function. [IP: 23.54.159.241 443]
Get:9 http://ports.ubuntu.com/ubuntu-ports bionic/main Translation-en [516 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports bionic/main Translation-en_GB [432 kB]
Err:11 https://repo.download.nvidia.com/jetson/t194 r32.5 Release
Get:12 http://ports.ubuntu.com/ubuntu-ports bionic/main arm64 DEP-11 Metadata [472 kB]
Get:13 http://ports.ubuntu.com/ubuntu-ports bionic/main DEP-11 48x48 Icons [118 kB]
Get:14 http://ports.ubuntu.com/ubuntu-ports bionic/main DEP-11 64x64 Icons [245 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports bionic/restricted arm64 Packages [664 B]
Get:16 http://ports.ubuntu.com/ubuntu-ports bionic/restricted Translation-en [3,584 B]
Get:17 http://ports.ubuntu.com/ubuntu-ports bionic/restricted Translation-en_GB [2,072 B]
Get:18 http://ports.ubuntu.com/ubuntu-ports bionic/universe arm64 Packages [8,316 kB]
Get:19 http://ports.ubuntu.com/ubuntu-ports bionic/universe Translation-en [4,941 kB]
Get:20 http://ports.ubuntu.com/ubuntu-ports bionic/universe Translation-en_GB [4,118 kB]
Get:21 http://ports.ubuntu.com/ubuntu-ports bionic/universe arm64 DEP-11 Metadata [3,243 kB]
Get:22 http://ports.ubuntu.com/ubuntu-ports bionic/universe DEP-11 48x48 Icons [2,151 kB]
Get:23 http://ports.ubuntu.com/ubuntu-ports bionic/universe DEP-11 64x64 Icons [8,420 kB]
Get:24 http://ports.ubuntu.com/ubuntu-ports bionic/multiverse arm64 Packages [126 kB]
Get:25 http://ports.ubuntu.com/ubuntu-ports bionic/multiverse Translation-en_GB [82.1 kB]
Get:26 http://ports.ubuntu.com/ubuntu-ports bionic/multiverse Translation-en [108 kB]
Get:27 http://ports.ubuntu.com/ubuntu-ports bionic/multiverse arm64 DEP-11 Metadata [44.4 kB]
Get:28 http://ports.ubuntu.com/ubuntu-ports bionic/multiverse DEP-11 48x48 Icons [8,931 B]
Get:29 http://ports.ubuntu.com/ubuntu-ports bionic/multiverse DEP-11 64x64 Icons [225 kB]
Get:30 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 Packages [1,294 kB]
Get:31 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main Translation-en [421 kB]
Get:32 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 DEP-11 Metadata [288 kB]
Get:33 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main DEP-11 48x48 Icons [82.0 kB]
Get:34 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main DEP-11 64x64 Icons [157 kB]
Get:35 http://ports.ubuntu.com/ubuntu-ports bionic-updates/restricted arm64 Packages [3,404 B]
Get:36 http://ports.ubuntu.com/ubuntu-ports bionic-updates/restricted Translation-en [52.6 kB]
Get:37 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe arm64 Packages [1,536 kB]
Get:38 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe Translation-en [371 kB]
Get:39 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe arm64 DEP-11 Metadata [284 kB]
Get:40 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe DEP-11 48x48 Icons [217 kB]
Get:41 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe DEP-11 64x64 Icons [497 kB]
Get:42 http://ports.ubuntu.com/ubuntu-ports bionic-updates/multiverse arm64 Packages [4,920 B]
Get:43 http://ports.ubuntu.com/ubuntu-ports bionic-updates/multiverse Translation-en [6,792 B]
Get:44 http://ports.ubuntu.com/ubuntu-ports bionic-updates/multiverse DEP-11 48x48 Icons [29 B]
Get:45 http://ports.ubuntu.com/ubuntu-ports bionic-updates/multiverse DEP-11 64x64 Icons [2,638 B]
Get:46 http://ports.ubuntu.com/ubuntu-ports bionic-backports/main arm64 Packages [9,992 B]
Get:47 http://ports.ubuntu.com/ubuntu-ports bionic-backports/main Translation-en [4,764 B]
Get:48 http://ports.ubuntu.com/ubuntu-ports bionic-backports/universe arm64 Packages [9,932 B]
Get:49 http://ports.ubuntu.com/ubuntu-ports bionic-backports/universe Translation-en [4,588 B]
Get:50 http://ports.ubuntu.com/ubuntu-ports bionic-backports/universe arm64 DEP-11 Metadata [9,272 B]
Get:51 http://ports.ubuntu.com/ubuntu-ports bionic-backports/universe DEP-11 48x48 Icons [2,809 B]
Get:52 http://ports.ubuntu.com/ubuntu-ports bionic-backports/universe DEP-11 64x64 Icons [3,943 B]
Get:53 http://ports.ubuntu.com/ubuntu-ports bionic-security/main arm64 Packages [996 kB]
Get:54 http://ports.ubuntu.com/ubuntu-ports bionic-security/main Translation-en [329 kB]
Get:55 http://ports.ubuntu.com/ubuntu-ports bionic-security/main arm64 DEP-11 Metadata [42.4 kB]
Get:56 http://ports.ubuntu.com/ubuntu-ports bionic-security/main DEP-11 48x48 Icons [28.4 kB]
Get:57 http://ports.ubuntu.com/ubuntu-ports bionic-security/main DEP-11 64x64 Icons [62.4 kB]
Get:58 http://ports.ubuntu.com/ubuntu-ports bionic-security/restricted arm64 Packages [2,852 B]
Get:59 http://ports.ubuntu.com/ubuntu-ports bionic-security/restricted Translation-en [48.9 kB]
Get:60 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe arm64 Packages [994 kB]
Get:61 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe Translation-en [256 kB]
Get:62 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe arm64 DEP-11 Metadata [55.5 kB]
Get:63 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe DEP-11 48x48 Icons [22.4 kB]
Get:64 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe DEP-11 64x64 Icons [132 kB]
Get:65 http://ports.ubuntu.com/ubuntu-ports bionic-security/multiverse arm64 Packages [2,732 B]
Get:66 http://ports.ubuntu.com/ubuntu-ports bionic-security/multiverse Translation-en [4,412 B]
Get:67 http://ports.ubuntu.com/ubuntu-ports bionic-security/multiverse DEP-11 48x48 Icons [29 B]
Get:68 http://ports.ubuntu.com/ubuntu-ports bionic-security/multiverse DEP-11 64x64 Icons [2,638 B]
Reading package lists... Done
E: The repository 'https://repo.download.nvidia.com/jetson/common r32.5 Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'https://repo.download.nvidia.com/jetson/t194 r32.5 Release' does not have a Release file.
If I add the [trusted=yes] to the apt sources file for the Nvidia repositories, the output becomes:
Hit:1 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
Hit:3 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
Ign:5 https://repo.download.nvidia.com/jetson/common r32.5 InRelease
Ign:7 https://repo.download.nvidia.com/jetson/common r32.5 Release
Ign:8 https://repo.download.nvidia.com/jetson/t194 r32.5 Release
Ign:9 https://repo.download.nvidia.com/jetson/common r32.5/main all Packages
Ign:10 https://repo.download.nvidia.com/jetson/common r32.5/main arm64 Packages
Ign:11 https://repo.download.nvidia.com/jetson/common r32.5/main Translation-en
Ign:12 https://repo.download.nvidia.com/jetson/common r32.5/main Translation-en_GB
Ign:13 https://repo.download.nvidia.com/jetson/common r32.5/main all DEP-11 Metadata
Ign:14 https://repo.download.nvidia.com/jetson/common r32.5/main arm64 DEP-11 Metadata
Ign:15 https://repo.download.nvidia.com/jetson/common r32.5/main DEP-11 48x48 Icons
Ign:16 https://repo.download.nvidia.com/jetson/common r32.5/main DEP-11 64x64 Icons
Ign:17 https://repo.download.nvidia.com/jetson/t194 r32.5/main all Packages
Ign:18 https://repo.download.nvidia.com/jetson/t194 r32.5/main arm64 Packages
Ign:19 https://repo.download.nvidia.com/jetson/t194 r32.5/main Translation-en_GB
Ign:20 https://repo.download.nvidia.com/jetson/t194 r32.5/main Translation-en
Ign:21 https://repo.download.nvidia.com/jetson/t194 r32.5/main arm64 DEP-11 Metadata
Ign:22 https://repo.download.nvidia.com/jetson/t194 r32.5/main all DEP-11 Metadata
Ign:23 https://repo.download.nvidia.com/jetson/t194 r32.5/main DEP-11 48x48 Icons
Ign:24 https://repo.download.nvidia.com/jetson/t194 r32.5/main DEP-11 64x64 Icons
Err:10 https://repo.download.nvidia.com/jetson/common r32.5/main arm64 Packages
Err:18 https://repo.download.nvidia.com/jetson/t194 r32.5/main arm64 Packages
E: Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r32.5/main/binary-arm64/Packages Could not handshake: Error in the pull function. [IP: 23.54.159.241 443]
E: Failed to fetch https://repo.download.nvidia.com/jetson/t194/dists/r32.5/main/binary-arm64/Packages Could not handshake: Error in the pull function. [IP: 23.54.159.241 443]
Can you share the full sdkmanager log from your ~/.nvsdkm?
Also, other users don’t hit this issue even without adding trusted=yes either. Is your current xavier in pure default jetpack status without any other modification (except trusted=yes)?
I have attached the log from the latest run.
The Xavier should be completely vanilla, the only change I have made as you point out is the [trusted=yes] in the sources.list.
sdkm-2021-06-28-14-45-54.log (1.0 MB)
Sorry, the correct log should be like multiple text files in a directory. Could you attach them as a tarball here?
I completely missed there was a logs directory!
I have tried several versions of Jetpack, but the latest run and version I want to use is using 4.5.1.
logs.zip (117.7 KB)
How about removing the nvidia source from the source list at this moment and see if you can apt update?
If I remove the Nvidia sources sudo apt update doesn’t error.
See if sdkmanager can install your sdk now.
Ok, so that seems to be working… Thanks for your help!
Just out of curiosity, what are those Nvidia repos for if they are not required for the SDK setup etc?
They are for the OTA udpate. For example, upgrading the jetpack from old version to latest version through apt-get upgrade.
Ohh ok, so not actually required if setting up through SDK Manager for a fresh install? That is good to know!
I still need to check why you cannot install sdkm with original setting. Will update later.
