JP5.0.2 - NX pinmux spreadsheet
I have a couple of questions:
  1. Is there a newer configuration template spreadsheet for the NX module under JetPack 5.0.2 compared to JetPack 4?
  2. For JetPack 5.0.2 what is the procedure used to generate the dtsi files from the spreadsheet and convert it to a .cfg?
Thanks,
Malcolm
hello malcolm.mcdowell,
you may use the same pinmux spreadsheets, which is v1.06.
please also refer to developer guide for Pinmux Changes session.
the process is same as JP-4, you’ll need to create dtsi files and covert them as cfg file for image flashing.
thanks
Thanks JerryChang
I assume if you have the cfg file from JP4, you can simply copy it to JP5 and use it. There is no need to re-create the cfg file.
