I have a Xavier NX on JP 5.0.2 and an external storage SATA SSD on it(SATA to PCIe converter)
I used the command to generate the mass flash image for boot from SATA
Waiting for target to boot-up...
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Run command: if [ -f /qspi/l4t_flash_from_kernel.sh ]; then USER=root /qspi/l4t_flash_from_kernel.sh --no-reboot --qspi-only ; fi on root@fe80::1%usb0
4194304
[ 0]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /media/nina/Data/caeg/s_mfi_jetson-xavier-nx-devkit-emmc/tools/kernel_flash/images/external/flash.idx
Number of lines is 13
max_index=12
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 3c2f759193a91c39966679a5f43fabeef7353ae6
Error: Error opening /dev/sde: No medium found
SSH ready
Error flashing non-qspi storage
Cleaning up...
So I tried to modify the driver
CONFIG_ATA=y
and flash fine, boot to SATA without issue
But I got a speed issue
May I ask why test mode 0(15W 2core)?
sorry, I clarified my question is the performance from mode5 to mode8
the speed drop between mode5 and mode8 seems only happen after the r35.1
