Hi Nvidia Team,
先前我們有客戶反應在Jetpack 6.1/6.2 版本上,
到oem configuration階段時, 會有黑畫面的情況(或只有游標
參考先前的文章有提到在下一個Jetpack版本會進行修正,
但我最近使用Jetpack 6.2.2在AGX Orin devkit進行驗證,
仍會有相同情況發生(OS燒錄到NVMe復現的機率較高
再麻煩協助看一下這個問題,
Thanks~
Hi Nvidia Team,
再麻煩協助看一下這個問題,
Thanks~
Based on the provided context, I’ll try to provide a comprehensive answer to your question.
It appears that you are inquiring about the Jetson AGX Orin, specifically regarding the OEM configuration, Jetpack 6.1.62, and the Jetpack 6.2 AGX Orin devkit with OS and NVMe.
Firstly, the Jetson AGX Orin is a high-performance AI computing module designed for edge AI applications. It is part of the NVIDIA Jetson family, which includes various modules such as the Jetson Orin NX, Jetson Orin Nano, and Jetson AGX Xavier.
Regarding the OEM configuration, it is likely that you are referring to the customization options available for the Jetson AGX Orin module. NVIDIA provides a range of tools and resources for OEMs to customize and integrate the Jetson AGX Orin into their products, including the Jetpack SDK, which includes the Linux operating system, CUDA, cuDNN, and other software components.
Jetpack 6.1.62 is a specific version of the Jetpack SDK, which includes support for the Jetson AGX Orin module. This version likely includes various bug fixes, performance enhancements, and new features compared to previous versions.
The Jetpack 6.2 AGX Orin devkit is a development kit specifically designed for the Jetson AGX Orin module. This kit likely includes the module, a carrier board, and other accessories, as well as the Jetpack SDK and other software tools.
Regarding the OS and NVMe, it is likely that you are inquiring about the operating system and storage options available for the Jetson AGX Orin module. The Jetson AGX Orin supports various operating systems, including Linux, and can be configured to use NVMe storage, which provides high-speed storage capabilities.
In comparison to other Jetson modules, the Jetson AGX Orin offers higher performance and more advanced features, making it suitable for demanding AI applications. However, the specific configuration and customization options may vary depending on the module and the OEM’s requirements.
To summarize, the Jetson AGX Orin is a high-performance AI computing module that can be customized and integrated into various products using the Jetpack SDK and other tools. The OEM configuration, Jetpack 6.1.62, and the Jetpack 6.2 AGX Orin devkit are specific versions and configurations that provide various features and capabilities for the Jetson AGX Orin module.
If you have any further questions or would like more specific information, please let me know.
Here are some additional resources that may be helpful:
I hope this information is helpful. Let me know if you have any further questions.
Hi ztna5483,
Could you share the full serial console log for further check?
How about the failed rate in your case?
Do you connect the display during flash?
