## Environment
- **Module**: P3767-0004
- **Software**: JetPack 7.2 / Jetson Linux **r39.2.0** (GCID 45755727), kernel `6.8.12-1021-tegra`, Ubuntu 24.04.4, UEFI `39.2.0-gcid-45755727`
- **Displays tested** (all plain HDMI-to-HDMI cables):
- two different small 7-inch-class HDMI panels from different vendors (one identified as **Daewoo CL07-HDMI**) → **both trigger the bug**
- one large **4K AOC** monitor → **never triggers the bug** (multiple cold boots)
- Boot from NVMe, X11 (WaylandEnable=false, nvidia X driver)
**Important context**: the exact same carrier board + these same small monitors ran **JetPack 6.x for a long time with zero issues** (display always connected at power-on). This only started with JP7.2, so we consider the monitors/EDID and our hardware ruled out.
To preempt the “custom board” question: our kernel/DT changes compared to stock r39.2 are **peripherals only** (WiFi/BT, CAN, MIPI cameras). The entire display pipeline — `display@13800000` / `dce@d800000` DT nodes, nvdisplay/DCE KMD, unified GPU driver, DCE firmware, UEFI — is **unmodified NVIDIA r39.2 code** (verified in our BSP git tree).
## Symptom
- **Small HDMI panel plugged in before power-on → system gets memory-corrupted and dies** (~100% reproducible over dozens of cold boots, both small panels)
- **The 4K AOC monitor plugged in before power-on → no problems at all** (multiple cold boots, clean every time)
- Plugging any of these displays **after** the system is up → everything works perfectly, indefinitely
- No display → everything works perfectly
So the bug is display-dependent: only the small panels trigger it. With a triggering panel at power-on and graphical target, the GDM greeter screen flickers and the machine freezes within ~16 s. With multi-user target it survives ~15 min as an idle text console, then hard-hangs silently (watchdog reset).
## What actually happens (captured on serial console)
At ~16 s the kernel enters an oops storm — **random physical memory is being scribbled by something**:
Internal error: Oops: 0000000096000044 [#1] PREEMPT SMP
CPU: 1 PID: 2362 Comm: gnome-shell
pc : __rmqueue_pcplist+0x104/0xaf4 x5 : dead000000000100 (LIST_POISON)
→ 15+ oopses within 5 s: __lruvec_stat_mod_folio, anon_vma_interval_tree_insert,
queued_spin_lock_slowpath, free_pcppages_bulk …
→ victims: gnome-shell, snapd, nm-dispatcher, kworkers, 7× udev-workers
→ i.e. struct page array / buddy lists / slab / dentries / user pages all corrupted
In parallel the **DCE firmware itself crashes twice** (Cortex-R5, loaded by UEFI from the `A_dce-fw` partition to 0x174000000, VA base 0x50000000):
Prefetch abort in user mode, Background fetching from 0x4f47a928
global worker@0x50248824 sp 0x5018fef0 …
(another instance: heap freelist walk loop — same PC 0x5000a754 repeated ~20× in the call stack)
**Notably: not a single arm-smmu context fault is logged during any of this.**
Corruption rate clearly scales with display activity:
| Configuration (all cold boots) | Outcome |
| HDMI + graphical target | oops storm, dead in ~16 s (multiple runs) |
| HDMI + multi-user (idle fbcon) | silent hard hang after ~15 min (multiple runs) |
| HDMI + multi-user, gdm started manually ~80 s after boot | healthy for the observation window |
| No HDMI, or HDMI hot-plugged after boot | healthy indefinitely |
## UEFI → kernel display handoff details (triggering small panel connected)
UEFI leaves in the kernel DT (captured with a triggering panel):
reserved-memory {
framebuffer@1,79E00000 { // node absent/disabled without a display
reg = <0x1 0x79e00000 0x0 0x800000>; // PA 0x179E00000, 8 MB
iommu-addresses = <&nvdisplay 0x1 0x79e00000 0x0 0x800000>; // identity IOVA
Note the 8 MB size — exactly one 1920×1080 AR24 frame. We have not yet dumped this node for the 4K monitor; if its framebuffer is sized/placed differently (a 4K frame is ~32 MB), that difference may be why it does not trigger.
Two kernel-side observations that we believe are the key:
1. At ~9.9 s: `iommu smmu.0x0000000010000000: IOMMU driver was not able to establish FW requested direct mapping.`
We instrumented `drivers/iommu/iommu.c` and found this warning is a **false positive**: the first `iommu_map()` returns `-19` (expected for arm-smmu, mapping before first attach), and the kernel’s retry 5 ms later **succeeds**:
DMDBG: 13800000.display: resv region [0x179e00000 + 0x800000] type=0 prot=0x3 pgsize=0x1000 dma_dom=1
DMDBG: 13800000.display: iommu_map(iova=0x179e00000 pa=0x179e00000 size=0x800000 prot=0x3) FAILED ret=-19
(no failure) → retry succeeded, mapping established
2. At ~14.4 s: `nv_platform 13800000.display: Cannot reserve IOVA region of 0 size` — from `drivers/iommu/of_iommu.c:264`.
The **same** `iommu-addresses` property that the iommu core path parses as a valid 8 MB region (see above) is parsed as **size 0** here, so the region is **not reserved**.
In fast-dying boots we additionally see the GPU ACR firmware fail to load (all 9 firmware paths, error -40) followed by `nvgpu_finalize_poweron: Failed initialization for: g->ops.acr.acr_construct_execute`, ~3 s before the corruption storm. We currently read this as a downstream victim of the early corruption rather than the root cause, since the same file loads fine when the GPU powers on later in a healthy boot.
Also present in *every* HDMI boot (including healthy ones), DCE firmware console prints:
`[dce_mem_init_from_gsc] Failed to get ast region 2 mapping`
## Our working hypothesis
Because the framebuffer’s IOVA region fails to get reserved (the size-0 parse), the DMA IOVA allocator on `smmu_iso` can hand the `0x179E00000` range to **other** buffers, while the display pipeline keeps using it as the identity-mapped framebuffer → the display engine’s writes land in whatever physical page now lives at that IOVA → random memory corruption whose rate scales with display activity. This matches every observation, including “hot-plug is fine” (no UEFI framebuffer → no identity region → no collision) and plausibly the monitor dependence (different EDID → different mode → different framebuffer size/placement; we have not yet dumped the DT handoff for the 4K monitor for comparison).
We have not yet been able to dump the domain mappings on a live corrupted boot to prove the double-allocation.
Here is the complete serial port abnormal startup log. We hope to receive any assistance.
jp72_forum_abnormal_boot.log (63.0 KB)
