I am working with a custom carrier board which resembles a simplified Dev Kit.
At this time, I have an issue with the HDMI interface which causes the system to fail to detect the NVME Memory devices when connected. We have tried a HDMI analyzer device between the Jetson Board and the monitor.
This is giving us inexplicable results. With just an unconnected HDMI cable, The debug serial port gets to a login state and properly acts as a serial terminal. With the Analyzer in place, I get a unexpected termination of activity with the processor being shut down. I would like to understand what the system is complaining about when the following is posted:
ERROR: Exception reason=0 syndrome=0xbe000011
ERROR: **************************************
ERROR: RAS Uncorrectable Error in IOB, base=0xe010000:
ERROR: Status = 0xec000612
ERROR: SERR = Error response from slave: 0x12
ERROR: IERR = CBB Interface Error: 0x6
ERROR: Overflow (there may be more errors) - Uncorrectable
ERROR: MISC0 = 0xc4520040
ERROR: MISC1 = 0x6cc860000000000
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: ADDR = 0x8000000003f400c0
ERROR: sdei_dispatch_event returned -1
ERROR: RAS Uncorrectable Error in ACI, base=0xe01a000:
ERROR: Status = 0xe8000904
ERROR: SERR = Assertion failure: 0x4
ERROR: IERR = FillWrite Error: 0x9
ERROR: Powering off core
When the HDMI is connected, the system boots to the EUFI loader and can be convinced to go to shell instead of looking for bootp servers on ethernet.
When in shell, the map command only shows
F51: Alias(s) F1:
MemmoryMapped(0xB,0x47200000,0x47230FFFF)
F52: Alias(s) F0:
Fv(49A79A15-8F69-4BE7-A30C-A172F44ABCE7)
with no persistant storage seen.
Debug logs attached
Login_putty_2026-06-08.log (81.9 KB)
Shutdown_putty_2026-06-07.log (39.2 KB)
