Hi - tried a few times but the Jupyter notebook doesn’t run any code … hit Shift+Enter and it’s just stuck at [*] for a basic Print statement (the very first one in the Getting Started with Deep Learning course). Any ideas ? Thanks in advance!
Can you try visiting this URL and making sure that you pass all tests? http://websocketstest.courses.nvidia.com/
If you don’t pass all of them, that means that either your network is preventing you from running WebSockets, which are required for our courses. If it’s your computer preventing you, you can try using an incognito tab and different browsers to see if they work.
If it doesn’t seem to be that, it means there’s a problem with the network you’re connected to blocking WebSockets. If this is the case, you’ll need to connect to a different network, either by toggling your VPN if you’re using one, or by connecting to another network like a mobile hotspot.
