hi i was using jetson nano devkit B00 for my driver development (jp4.6) and while rmmod and modprobe my module that cause the kernel crash please refer the image
hello herethehacker97,
did you remove the module while camera in used?
besides,
since the latest JP-4 release version is JetPack 4.6.5.
may I double confirm the Jetpack release version you’re working with.
you may check release tag for confirmation, i.e. $ cat /etc/nv_tegra_release
The issue is during the rmmod and insmod the ko and we didn’t remove the camera module
we have confirmed the jetpack version is(4.6)
R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t210ref, EABI: aarch64, DATE: Mon Jul 26 19:20:30 UTC 2021
do you have complete logs.
the screenshot should be kernel panic reported while modprobe, right?
anyways,
is it possible for moving forward to the latest release version for verification.
yes the kernel crash is during modprobe .
the complete log for the kernel crash
Our requirement is for 4.6 .so can i get the some solution on this issues.
it looks device still register as a video node, although kernel panic reports, is it correct?
for instance,
[ 3060.012776] vi 54080000.vi: subdev eimx462 8-0042 bound
[ 3060.018677] eimx462 8-0042: Detected IMX462 sensor
this seems like a culprit, [ 3059.965171] eimx462 8-0042: mclk not in DT.
since the kernel panic reported by calling camera_common_mclk_enable
could you please try below to identify the issue.
diff --git a/drivers/media/platform/tegra/camera/camera_common.c
@@ -849,6 +849,8 @@
int camera_common_mclk_enable(struct camera_common_data *s_data)
int err;
+ return 0;
Hi @JerryChang i have tried the above changes in the camera_common.c still the issue there.
the changes i made are
int err;
struct camera_common_power_rail *pw = s_data->power;
unsigned long mclk_init_rate = s_data->def_clk_freq;
return 0;
if (!pw) {
dev_err(s_data->dev, "%s: no device power rail\n",
__func__);
return -ENODEV;
dev_dbg(s_data->dev, "%s: enable MCLK with %lu Hz\n",
__func__, mclk_init_rate);
err = clk_set_rate(pw->mclk, mclk_init_rate);
if (!err)
err = clk_prepare_enable(pw->mclk);
return err;
may I confirm this as well,
yes kernel panic and video node is registered
so, it’s the issue within the sensor driver, please contact with sensor vendor for root cause.
