Kernel customization - Wrong Path in Developer Guide of JetPack 7.2
Dear Nvidia
In the developer guide, after building the dtbs, the following command should be used:
cp kernel-devicetree/generic-dts/dtbs/* /Linux_for_Tegra/kernel/dtb/
The path “kernel-devicetree” is not available anymore. Should this be changed to “build/nvidia-public/devicetree/generic-dtbs/”?
Thank you.
Kind regards
Hi @sevm89 ,
I’m facing the exact same issue here[Link]. My current workaround is the same as yours. Although we are still waiting for an official confirmation or response from NVIDIA, this method has been working fine for me so far without any issues.
Thanks!!
Many if not all are in this deb and get installed to rootfs with ./apply_binaries.sh --openrm
cd jp7.2/Linux_for_Tegra/kernel
mkdir tmp
dpkg-deb -R nvidia-l4t-kernel-dtbs_6.8.12-tegra-39.2.0-20260601141651_arm64.deb tmp/
ls tmp/boot/
Thank you for your feedback.
We have updated the path but did not revise the developer guide accordingly.
We will correct this as soon as possible.
The correct version will be released in the next update.
