Kernel error "scare-pigeon"
I have a test system for car multimedia and I encountered a kernel error in the system logs:
“kernel: Error: scare-pigeon 13e10000.host1x:vi-thi@15f00000: nvhost_syncpt_get_cv_dev_address_table: failed to fetch_cv_dev_info”
It seems to work with it at first(does not crash at the time it appears), but I cannot find any information on why it appears, if there are other problems.
Does anyone has some insight about this?
Thank you!
I have the same issue. Could you fix it?
Is this appearing on ARM (Jetson/Tegra) platforms? In that case, you might get more info on the appropriate forums:
https://forums.developer.nvidia.com/c/agx-autonomous-machines/jetson-embedded-systems/70
This forum is mainly about the x86 driver.
