Hi there,
I’ve a tx2 connected to a 4K camera via a tosh bridge. Have had this setup working ok on a difrent carrier board but I seem to be encountering a weird crash that I’m struggling to understand the root cause of.
here’s a few syslog snippets of the fault:
Oct 13 20:23:27 myTx2-Host kernel: page:ffffffbf06b41c00 count:0 mapcount:-16711935 mapping:0000000000000004 index:0x0
Oct 13 20:23:27 myTx2-Host kernel: flags: 0x4004000400000000()
Oct 13 20:23:27 myTx2-Host kernel: page dumped because: VM_BUG_ON_PAGE(page_ref_count(page) == 0)
Oct 13 20:23:30 myTx2-Host kernel: ------------[ cut here ]------------
Oct 13 20:23:30 myTx2-Host kernel: kernel BUG at /home/hannaBarbera/Jetson_R32_Kernel_4.9/linux-tegra-4.9/include/linux/mm.h:455!
Oct 13 20:23:30 myTx2-Host kernel: Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
-- Reboot --
Oct 13 20:24:45 myTx2-Host kernel: Booting Linux on physical CPU 0x100
Sep 24 14:09:20 myTx2-Host systemd[1]: dev-mmcblk2p1.device: Job dev-mmcblk2p1.device/start timed out.
Sep 24 14:09:20 myTx2-Host systemd[1]: Timed out waiting for device dev-mmcblk2p1.device.
Sep 24 14:09:20 myTx2-Host systemd[1]: Dependency failed for /media/mySdCard.
Sep 24 14:09:20 myTx2-Host systemd[1]: media-internal\x2dstorage\x2d1.mount: Job media-internal\x2dstorage\x2d1.mount/start failed with result 'dependency'.
Sep 24 14:09:20 myTx2-Host systemd[1]: Startup finished in 3.807s (kernel) + 1min 30.594s (userspace) = 1min 34.402s.
Sep 24 14:09:20 myTx2-Host systemd[1]: dev-mmcblk2p1.device: Job dev-mmcblk2p1.device/start failed with result 'timeout'.
Sep 24 14:09:24 myTx2-Host kernel: [ 97.926873] Unable to handle kernel paging request at virtual address 80ff80c100470248
Sep 24 14:09:24 myTx2-Host kernel: [ 97.926961] Mem abort info:
Sep 24 14:09:24 myTx2-Host kernel: [ 97.926991] ESR = 0x96000004
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927025] Exception class = DABT (current EL), IL = 32 bits
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927077] SET = 0, FnV = 0
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927108] EA = 0, S1PTW = 0
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927139] Data abort info:
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927169] ISV = 0, ISS = 0x00000004
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927204] CM = 0, WnR = 0
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927235] [80ff80c100470248] address between user and kernel address ranges
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927298] Internal error: Oops: 96000004 [#1] PREEMPT SMP
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927348] Modules linked in: 88XXau(O) zram bma400_i2c bma400_core bcmdhd cfg80211 spidev bluedroid_pm ip_tables x_tables
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927522] CPU: 5 PID: 17316 Comm: lsblk Tainted: G O 4.9.140_v0.01.03-g147e705dde7e #243
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927597] Hardware name: quill (DT)
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927635] task: ffffffc1cd670000 task.stack: ffffffc19cc90000
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927694] PC is at __ll_sc_atomic_add+0x4/0x18
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927740] LR is at __remove_shared_vm_struct+0x3c/0x88
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927788] pc : [<ffffff800846cda4>] lr : [<ffffff8008204ccc>] pstate: 60400045
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927849] sp : ffffffc19cc93c80
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927881] x29: ffffffc19cc93c80 x28: ffffffc1cd670000
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927940] x27: ffffff8008ff2000 x26: 000000000000005e
Sep 24 14:09:24 myTx2-Host kernel: [ 97.927997] x25: ffffffc1e0d1ce68 x24: 0000000000000000
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928054] x23: 0000000000000000 x22: ffffffc1cc478260
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928110] x21: ffffffc1b1a5e700 x20: ffffffc1b434f580
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928166] x19: ffffffc1cc478260 x18: 00000000000005c3
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928222] x17: ffffffff00000001 x16: 0000000000000000
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928278] x15: 0000007fa4ebfe08 x14: 0000007fa4ecd308
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928334] x13: 0000007fa517c400 x12: 0000007fa517a060
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928390] x11: 0000000000000000 x10: 0101010101010101
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928446] x9 : 0000007fa5179b60 x8 : 000000000000005e
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928502] x7 : 0000008002377000 x6 : 00000041ed7a4000
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928558] x5 : 00000041ed7a4000 x4 : 00000000ffffffd6
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928614] x3 : 0000000000000000 x2 : 80ff80c1004700e8
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928670] x1 : 80ff80c100470248 x0 : 0000000000000001
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928726]
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928747] Process lsblk (pid: 17316, stack limit = 0xffffffc19cc90000)
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928803] Call trace:
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928834] [<ffffff800846cda4>] __ll_sc_atomic_add+0x4/0x18
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928885] [<ffffff8008205704>] unlink_file_vma+0x44/0x60
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928937] [<ffffff80081fce68>] free_pgtables+0x48/0x100
Sep 24 14:09:24 myTx2-Host kernel: [ 97.928986] [<ffffff800820750c>] exit_mmap+0xac/0x118
Sep 24 14:09:24 myTx2-Host kernel: [ 97.929034] [<ffffff80080af968>] mmput+0x60/0x130
Sep 24 14:09:24 myTx2-Host kernel: [ 97.929078] [<ffffff80080b8a2c>] do_exit+0x26c/0xa08
Sep 24 14:09:24 myTx2-Host kernel: [ 97.929124] [<ffffff80080b9258>] do_group_exit+0x40/0xa8
Sep 24 14:09:24 myTx2-Host kernel: [ 97.929172] [<ffffff80080b92e0>] __wake_up_parent+0x0/0x40
Sep 24 14:09:24 myTx2-Host kernel: [ 97.929222] [<ffffff80080838c0>] el0_svc_naked+0x34/0x38
Sep 24 14:09:24 myTx2-Host kernel: [ 97.929272] ---[ end trace 976c59c3ce2640ad ]---
Sep 24 14:09:24 myTx2-Host kernel: [ 97.949052] Fixing recursive fault but reboot is needed!
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620145] Unable to handle kernel paging request at virtual address 74ff74c100d300c0
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620238] Mem abort info:
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620268] ESR = 0x96000004
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620302] Exception class = DABT (current EL), IL = 32 bits
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620352] SET = 0, FnV = 0
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620382] EA = 0, S1PTW = 0
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620412] Data abort info:
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620441] ISV = 0, ISS = 0x00000004
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620475] CM = 0, WnR = 0
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620506] [74ff74c100d300c0] address between user and kernel address ranges
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620567] Internal error: Oops: 96000004 [#1] PREEMPT SMP
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620616] Modules linked in: 88XXau(O) zram bcmdhd bma400_i2c bma400_core cfg80211 spidev bluedroid_pm ip_tables x_tables
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620780] CPU: 4 PID: 6845 Comm: lsblk Tainted: G O 4.9.140_v0.01.03-g147e705dde7e #243
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620853] Hardware name: quill (DT)
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620889] task: ffffffc1d52b0e00 task.stack: ffffffc1b0668000
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620947] PC is at unmap_page_range+0x5c/0x290
Sep 25 00:33:06 myTx2-Host kernel: [ 269.620991] LR is at unmap_single_vma+0x7c/0x90
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621032] pc : [<ffffff80081feadc>] lr : [<ffffff80081fed8c>] pstate: 80400045
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621091] sp : ffffffc1b066bc30
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621123] x29: ffffffc1b066bc30 x28: ffffffc1d52b0e00
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621179] x27: ffffff8008ff2000 x26: 0000007f8afd1000
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621235] x25: ffffffc1dfd374e8 x24: 0000007f8afe0000
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621291] x23: 0000000000000000 x22: ffffffc1b066bd48
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621346] x21: 00000000000001fe x20: ffffffc1b071b840
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621400] x19: 0000000000000000 x18: 00000000000005c3
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621455] x17: 0000000000000214 x16: 0000000000000000
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621509] x15: 0000007f8b033e08 x14: 0000007f8b041308
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621564] x13: 0000007f8b2f0400 x12: 0000007f8b2ee060
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621618] x11: 0000000000000000 x10: 0101010101010101
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621673] x9 : 0000007f8b2edb60 x8 : 000000000000005e
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621728] x7 : 0000007fcafba000 x6 : 00000041ed78b000
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621782] x5 : 0000000000000000 x4 : 0000000000000000
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621836] x3 : 0000007f8afe0000 x2 : 0000007f8afd1000
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621891] x1 : 0000007f8afdffff x0 : 74ff74c100d30080
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621945]
Sep 25 00:33:06 myTx2-Host kernel: [ 269.621966] Process lsblk (pid: 6845, stack limit = 0xffffffc1b0668000)
Sep 25 00:33:06 myTx2-Host kernel: [ 269.622020] Call trace:
Sep 25 00:33:06 myTx2-Host kernel: [ 269.622050] [<ffffff80081feadc>] unmap_page_range+0x5c/0x290
Sep 25 00:33:06 myTx2-Host kernel: [ 269.622100] [<ffffff80081fed8c>] unmap_single_vma+0x7c/0x90
Sep 25 00:33:06 myTx2-Host kernel: [ 269.622149] [<ffffff80081ff0a8>] unmap_vmas+0x70/0xe0
Sep 25 00:33:06 myTx2-Host kernel: [ 269.622195] [<ffffff80082074f8>] exit_mmap+0x98/0x118
Sep 25 00:33:06 myTx2-Host kernel: [ 269.622241] [<ffffff80080af968>] mmput+0x60/0x130
Sep 25 00:33:06 myTx2-Host kernel: [ 269.622284] [<ffffff80080b8a2c>] do_exit+0x26c/0xa08
Sep 25 00:33:06 myTx2-Host kernel: [ 269.622330] [<ffffff80080b9258>] do_group_exit+0x40/0xa8
Sep 25 00:33:06 myTx2-Host kernel: [ 269.622377] [<ffffff80080b92e0>] __wake_up_parent+0x0/0x40
Sep 25 00:33:06 myTx2-Host kernel: [ 269.622426] [<ffffff80080838c0>] el0_svc_naked+0x34/0x38
Sep 25 00:33:06 myTx2-Host kernel: [ 269.622474] ---[ end trace 6f84b39c808e4d39 ]---
Sep 25 00:33:06 myTx2-Host kernel: [ 269.631085] Fixing recursive fault but reboot is needed!
Sep 25 00:33:24 myTx2-Host kernel: [ 287.273637] Unable to handle kernel paging request at virtual address ff00c100f60080
Sep 25 00:33:24 myTx2-Host kernel: [ 287.273902] Mem abort info:
Sep 25 00:33:24 myTx2-Host kernel: [ 287.274007] ESR = 0x96000004
Sep 25 00:33:24 myTx2-Host kernel: [ 287.274118] Exception class = DABT (current EL), IL = 32 bits
Sep 25 00:33:24 myTx2-Host kernel: [ 287.274295] SET = 0, FnV = 0
Sep 25 00:33:24 myTx2-Host kernel: [ 287.274400] EA = 0, S1PTW = 0
Sep 25 00:33:24 myTx2-Host kernel: [ 287.274504] Data abort info:
Sep 25 00:33:24 myTx2-Host kernel: [ 287.274588] ISV = 0, ISS = 0x00000004
Sep 25 00:33:24 myTx2-Host kernel: [ 287.274673] CM = 0, WnR = 0
Sep 25 00:33:24 myTx2-Host kernel: [ 287.274745] [00ff00c100f60080] address between user and kernel address ranges
Sep 25 00:33:24 myTx2-Host kernel: [ 287.274894] Internal error: Oops: 96000004 [#2] PREEMPT SMP
Sep 25 00:33:24 myTx2-Host kernel: [ 287.275012] Modules linked in: 88XXau(O) zram bcmdhd bma400_i2c bma400_core cfg80211 spidev bluedroid_pm ip_tables x_tables
Sep 25 00:33:24 myTx2-Host kernel: [ 287.275389] CPU: 0 PID: 6873 Comm: free Tainted: G D O 4.9.140_v0.01.03-g147e705dde7e #243
Sep 25 00:33:24 myTx2-Host kernel: [ 287.275571] Hardware name: quill (DT)
Sep 25 00:33:24 myTx2-Host kernel: [ 287.275658] task: ffffffc1dc3ae200 task.stack: ffffffc1dcae0000
Sep 25 00:33:24 myTx2-Host kernel: [ 287.275792] PC is at __rb_insert_augmented+0x2c/0x220
Sep 25 00:33:24 myTx2-Host kernel: [ 287.275907] LR is at vma_interval_tree_insert+0x94/0xa0
Sep 25 00:33:24 myTx2-Host kernel: [ 287.276020] pc : [<ffffff8008477bfc>] lr : [<ffffff80081f757c>] pstate: 604001c5
Sep 25 00:33:24 myTx2-Host kernel: [ 287.276166] sp : ffffffc1dcae3af0
Sep 25 00:33:24 myTx2-Host kernel: [ 287.276243] x29: ffffffc1dcae3af0 x28: ffffffc1dc477480
Sep 25 00:33:24 myTx2-Host kernel: [ 287.276381] x27: 0000007f85dab000 x26: ffffffc1e4bb6700
Sep 25 00:33:24 myTx2-Host kernel: [ 287.276516] x25: 0000000000000000 x24: ffffffc1e4bb66e0
Sep 25 00:33:24 myTx2-Host kernel: [ 287.276649] x23: 0000000000000000 x22: ffffffc1e4bb6700
Sep 25 00:33:24 myTx2-Host kernel: [ 287.276781] x21: ffffff80081f7298 x20: ffffffc1e4bb6700
Sep 25 00:33:24 myTx2-Host kernel: [ 287.276913] x19: 00ff00c100f60078 x18: 000000000004098c
Sep 25 00:33:24 myTx2-Host kernel: [ 287.277044] x17: ffffffff00000001 x16: 0000000000000000
Sep 25 00:33:24 myTx2-Host kernel: [ 287.277175] x15: 7fffffffffffffff x14: ffffffc1a11d06a8
Sep 25 00:33:24 myTx2-Host kernel: [ 287.277306] x13: 000000000000002b x12: 0000000000000000
Sep 25 00:33:24 myTx2-Host kernel: [ 287.277437] x11: 0000000000000000 x10: ffffffc1a11d0948
Sep 25 00:33:24 myTx2-Host kernel: [ 287.277568] x9 : 0000000000000075 x8 : 0000000000000026
Sep 25 00:33:24 myTx2-Host kernel: [ 287.277699] x7 : ffffffc1a11d0688 x6 : 0000000000000010
Sep 25 00:33:24 myTx2-Host kernel: [ 287.277830] x5 : ffffffc1a11d0948 x4 : ffffffc1a11d0948
Sep 25 00:33:24 myTx2-Host kernel: [ 287.277960] x3 : ffffffc1a11d0688 x2 : ffffffc1a84df318
Sep 25 00:33:24 myTx2-Host kernel: [ 287.278092] x1 : ffffffc1b071b898 x0 : ffffffc1a11d0948
Sep 25 00:33:24 myTx2-Host kernel: [ 287.278222]
Sep 25 00:33:24 myTx2-Host kernel: [ 287.278272] Process free (pid: 6873, stack limit = 0xffffffc1dcae0000)
Sep 25 00:33:24 myTx2-Host kernel: [ 287.278404] Call trace:
Sep 25 00:33:24 myTx2-Host kernel: [ 287.278475] [<ffffff8008477bfc>] __rb_insert_augmented+0x2c/0x220
Sep 25 00:33:24 myTx2-Host kernel: [ 287.278606] [<ffffff80081f757c>] vma_interval_tree_insert+0x94/0xa0
Sep 25 00:33:24 myTx2-Host kernel: [ 287.278740] [<ffffff8008204d7c>] __vma_link_file+0x64/0x90
Sep 25 00:33:24 myTx2-Host kernel: [ 287.278858] [<ffffff8008205a18>] __vma_adjust+0x168/0x7d0
Sep 25 00:33:24 myTx2-Host kernel: [ 287.278973] [<ffffff800820618c>] __split_vma.isra.4+0x10c/0x1c0
Sep 25 00:33:24 myTx2-Host kernel: [ 287.279099] [<ffffff80082063c8>] do_munmap+0x188/0x3a8
Sep 25 00:33:24 myTx2-Host kernel: [ 287.279211] [<ffffff800820863c>] mmap_region+0x1ac/0x560
Sep 25 00:33:24 myTx2-Host kernel: [ 287.279324] [<ffffff8008208bf0>] do_mmap+0x200/0x3c0
Sep 25 00:33:24 myTx2-Host kernel: [ 287.279436] [<ffffff80081e7d94>] vm_mmap_pgoff+0xac/0xd0
Sep 25 00:33:24 myTx2-Host kernel: [ 287.279549] [<ffffff8008206ae0>] SyS_mmap_pgoff+0x78/0x110
Sep 25 00:33:24 myTx2-Host kernel: [ 287.279670] [<ffffff800808b710>] sys_mmap+0x58/0x78
Sep 25 00:33:24 myTx2-Host kernel: [ 287.279778] [<ffffff80080838c0>] el0_svc_naked+0x34/0x38
Sep 25 00:33:24 myTx2-Host kernel: [ 287.279895] ---[ end trace 6f84b39c808e4d3a ]---
Sep 25 00:33:24 myTx2-Host kernel: [ 287.299910] note: free[6873] exited with preempt_count 1
Any ideas would be appreciated, thanks.
