Kernel panic occurred after restarting the process.
I use TX2 tegra-l4t-r28.2.1 (kernel 4.4.38)
- Reproducing path
- Kill a running specific process
- Update specific process
- Run specific process
Kernel panic occurred in step 1. (Kernel panic has occurred once)
Unable to handle kernel paging request at virtual address 6cf2f3c000000001
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434483] [6cf2f3c000000001] *pgd=0000000000000000, *pud=0000000000000000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434486] Internal error: Oops: 96000004 [#1] PREEMPT SMP
I share sys.log Please analyze and reply.
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.181278] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.240329] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.299080] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.358964] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.418605] xhci-tegra 3530000.xhci: WARN: Success on ctrl data TRB without IOC set??
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.426433] xhci-tegra 3530000.xhci: WARN: Success on ctrl data TRB without IOC set??
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434425] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434464] mttcan c310000.mttcan can0: mttcan_poll_ir: some msgs lost on in Q0
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434479] Unable to handle kernel paging request at virtual address 6cf2f3c000000001
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434480] pgd = ffffffc1e2291000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434504] Modules linked in: fuse ipt_MASQUERADE nf_nat_masquerade_ipv4 iptable_nat nf_nat_ipv4 xt_addrtype iptable_filter ip_tables xt_conntrack nf_nat br_netfilter overlay mttcan can_dev can_raw can hid_sensor_gyro_3d hid_sensor_accel_3d hid_sensor_trigger hid_sensor_iio_common industrialio_triggered_buffer kfifo_buf hid_sensor_hub uvcvideo videobuf2_vmalloc r8169 bcmdhd pci_tegra bluedroid_pm
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434507] CPU: 3 PID: 293 Comm: systemd-journal Not tainted 4.4.38-tegra #1
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434508] Hardware name: quill (DT)
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434510] task: ffffffc1e0932580 ti: ffffffc1e09c4000 task.ti: ffffffc1e09c4000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434517] PC is at kmem_cache_alloc+0xa4/0x22c
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434520] LR is at kernfs_fop_open+0x30c/0x358
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434522] pc : [] lr : [] pstate: 60000045
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434522] sp : ffffffc1e09c7a90
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434524] x29: ffffffc1e09c7a90 x28: 00000000024000c0
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434526] x27: ffffffc0010bd000 x26: ffffffc001268000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434527] x25: ffffffc00020ea00 x24: ffffffc1ecd553f8
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434529] x23: ffffffc1e09c7a90 x22: 00000000028c2683
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434530] x21: 6cf2f3c000000001 x20: ffffffc1e09c4000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434532] x19: ffffffc1f6640e00 x18: 0000000000000032
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434533] x17: 0000007fb30ee3b0 x16: ffffffc0001a4d64
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434534] x15: 0000000000000050 x14: ff00000000000000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434536] x13: ffffffff00000000 x12: 0101010101010101
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434537] x11: 0000000000000030 x10: 0101010101010101
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434539] x9 : 0000000000000000 x8 : ffffffc1de819100
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434540] x7 : 0000000000000000 x6 : ffffffc0011e8170
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434541] x5 : 0000000000000040 x4 : ffffffc001263000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434543] x3 : 0000000000000000 x2 : 00000001f4f45000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434544] x1 : 0000000000000000 x0 : 0000000000000000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434545] Process systemd-journal (pid: 293, stack limit = 0xffffffc1e09c4020)
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434546] Call trace:
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434549] [] kmem_cache_alloc+0xa4/0x22c
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434551] [] kernfs_fop_open+0x30c/0x358
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434555] [] do_dentry_open+0x1e0/0x2f8
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434557] [] vfs_open+0x50/0x7c
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434560] [] do_last+0x120/0xbec
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434561] [] path_openat+0x74/0x2b4
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434563] [] do_filp_open+0x58/0xb0
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434566] [] do_sys_open+0x140/0x21c
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434568] [] SyS_openat+0x10/0x18
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434571] [] el0_svc_naked+0x24/0x28
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.434964] —[ end trace e539f70082e21a56 ]—
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436073] Unable to handle kernel paging request at virtual address 6cf2f3c000000001
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436074] pgd = ffffffc1e2291000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436076] [6cf2f3c000000001] *pgd=0000000000000000, *pud=0000000000000000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436078] Internal error: Oops: 96000004 [#2] PREEMPT SMP
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436093] Modules linked in: fuse ipt_MASQUERADE nf_nat_masquerade_ipv4 iptable_nat nf_nat_ipv4 xt_addrtype iptable_filter ip_tables xt_conntrack nf_nat br_netfilter overlay mttcan can_dev can_raw can hid_sensor_gyro_3d hid_sensor_accel_3d hid_sensor_trigger hid_sensor_iio_common industrialio_triggered_buffer kfifo_buf hid_sensor_hub uvcvideo videobuf2_vmalloc r8169 bcmdhd pci_tegra bluedroid_pm
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436096] CPU: 3 PID: 293 Comm: systemd-journal Tainted: G D 4.4.38-tegra #1
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436096] Hardware name: quill (DT)
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436098] task: ffffffc1e0932580 ti: ffffffc1e09c4000 task.ti: ffffffc1e09c4000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436103] PC is at __kmalloc_track_caller+0xb8/0x278
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436104] LR is at __kmalloc_track_caller+0x30/0x278
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436106] pc : [] lr : [] pstate: 600001c5
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436106] sp : ffffffc1e09c7500
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436108] x29: ffffffc1e09c7500 x28: ffffffc0010bd000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436109] x27: ffffffc001268000 x26: ffffffc0002fc3c0
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436111] x25: 0000000002080020 x24: ffffffc0010e0000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436112] x23: ffffffc1e09c7500 x22: 00000000028c2683
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436114] x21: 6cf2f3c000000001 x20: ffffffc1e09c4000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436115] x19: ffffffc1f6640e00 x18: 0000000000000032
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436116] x17: 0000007fb30ee3b0 x16: ffffffc0001a4d64
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436118] x15: 0000000000000050 x14: 3463393065316366
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436119] x13: 6666666666783020 x12: 3d2074696d696c20
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436120] x11: 6b63617473202c33 x10: ffffffc000288798
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436122] x9 : 000000000000ffa7 x8 : 000000000000fff9
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436123] x7 : 0000000000000006 x6 : 000000000000002c
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436124] x5 : ffffffc0002f7ba8 x4 : ffffffc0002f7cd8
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436126] x3 : 0000000000000001 x2 : 00000000028c2683
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436127] x1 : 0000000000000000 x0 : 0000000000000000
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436129] Process systemd-journal (pid: 293, stack limit = 0xffffffc1e09c4020)
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436129] Call trace:
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436131] [] __kmalloc_track_caller+0xb8/0x278
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436136] [] kvasprintf+0x64/0xa4
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436137] [] kasprintf+0x58/0x60
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436141] [] ramoops_pstore_write_buf+0xbc/0x1fc
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436143] [] pstore_write_compat+0x20/0x28
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436145] [] pstore_dump+0x144/0x418
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436148] [] kmsg_dump+0xac/0xd4
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436153] [] oops_exit+0x28/0x30
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436158] [] die+0xe0/0x1a8
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436161] [] __do_kernel_fault.part.6+0x74/0x84
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436164] [] cpu_enable_pan+0x0/0x48
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436166] [] do_mem_abort+0x40/0xa0
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436168] [] el1_da+0x18/0x78
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436171] [] kernfs_fop_open+0x30c/0x358
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436176] [] do_dentry_open+0x1e0/0x2f8
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436179] [] vfs_open+0x50/0x7c
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436181] [] do_last+0x120/0xbec
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436183] [] path_openat+0x74/0x2b4
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436185] [] do_filp_open+0x58/0xb0
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436187] [] do_sys_open+0x140/0x21c
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436190] [] SyS_openat+0x10/0x18
Jul 28 23:03:29 tegra-ubuntu kernel: [ 1871.436192] [] el0_svc_naked+0x24/0x28
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1871.436461] —[ end trace e539f70082e21a57 ]—
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1871.436850] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1871.487374] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1871.563905] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1871.614059] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1871.664496] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1871.715078] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1871.765221] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1871.836029] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1871.886224] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1871.956913] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.027839] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.098546] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.161924] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.240883] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.299676] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.440291] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.505233] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.564226] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.644324] uvcvideo: Failed to query (GET_CUR) UVC control 2 on unit 3: -32 (exp. 1).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.664286] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.707119] uvcvideo: Failed to query (GET_CUR) UVC control 2 on unit 3: -32 (exp. 1).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.811547] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.873229] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:30 tegra-ubuntu kernel: [ 1872.955603] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:31 tegra-ubuntu kernel: [ 1873.017836] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:31 tegra-ubuntu kernel: [ 1873.135332] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:31 tegra-ubuntu kernel: [ 1873.312516] uvcvideo: Failed to query (GET_CUR) UVC control 1 on unit 3: -32 (exp. 1024).
Jul 28 23:03:31 tegra-ubuntu kernel: [ 1873.320835] mttcan c310000.mttcan can0: mttcan_poll_ir: some msgs lost on in Q0
Jul 28 23:03:50 tegra-ubuntu kernel: [ 1892.446087] INFO: rcu_preempt detected stalls on CPUs/tasks:
Jul 28 23:03:50 tegra-ubuntu kernel: [ 1892.451752] 3-…: (1 GPs behind) idle=63b/140000000000000/0 softirq=297836/297837 fqs=4869
Jul 28 23:03:50 tegra-ubuntu kernel: [ 1892.460260] (detected by 0, t=5252 jiffies, g=164238, c=164237, q=17785)
Jul 28 23:03:50 tegra-ubuntu kernel: [ 1892.467041] Task dump for CPU 3:
Jul 28 23:03:50 tegra-ubuntu kernel: [ 1892.470260] systemd-journal R running task 0 293 1 0x00000002
Jul 28 23:03:50 tegra-ubuntu kernel: [ 1892.477311] Call trace:
Jul 28 23:03:50 tegra-ubuntu kernel: [ 1892.479756] [] __switch_to+0xa4/0xb0
Jul 28 23:03:50 tegra-ubuntu kernel: [ 1892.484884] [] 0xffffffc1e09c7e80
Jul 28 23:03:50 tegra-ubuntu rsyslogd-2007: action ‘action 9’ suspended, next retry is Tue Jul 28 23:04:50 2020 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Jul 28 23:03:51 tegra-ubuntu kernel: [ 1893.294085] INFO: rcu_sched detected stalls on CPUs/tasks:
Jul 28 23:03:51 tegra-ubuntu kernel: [ 1893.299569] 3-…: (1 GPs behind) idle=63b/140000000000000/0 softirq=297629/297837 fqs=4824
Jul 28 23:03:51 tegra-ubuntu kernel: [ 1893.308074] (detected by 0, t=5252 jiffies, g=54186, c=54185, q=851)
Jul 28 23:03:51 tegra-ubuntu kernel: [ 1893.314510] Task dump for CPU 3:
Jul 28 23:03:51 tegra-ubuntu kernel: [ 1893.317728] systemd-journal R running task 0 293 1 0x00000002
Jul 28 23:03:51 tegra-ubuntu kernel: [ 1893.324780] Call trace:
Jul 28 23:03:51 tegra-ubuntu kernel: [ 1893.327223] [] __switch_to+0xa4/0xb0
Jul 28 23:03:51 tegra-ubuntu kernel: [ 1893.332349] [] 0xffffffc1e09c7e80
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.720688] Watchdog detected hard LOCKUP on cpu 3
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.725338] ------------[ cut here ]------------
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.730137] WARNING: at ffffffc00013288c [verbose debug info unavailable]
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.736928] Modules linked in: fuse ipt_MASQUERADE nf_nat_masquerade_ipv4 iptable_nat nf_nat_ipv4 xt_addrtype iptable_filter ip_tables xt_conntrack nf_nat br_netfilter overlay mttcan can_dev can_raw can hid_sensor_gyro_3d hid_sensor_accel_3d hid_sensor_trigger hid_sensor_iio_common industrialio_triggered_buffer kfifo_buf hid_sensor_hub uvcvideo videobuf2_vmalloc r8169 bcmdhd pci_tegra bluedroid_pm
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.772357]
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.773851] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.38-tegra #1
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.781492] Hardware name: quill (DT)
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.785160] task: ffffffc1ec8b9900 ti: ffffffc1ec8cc000 task.ti: ffffffc1ec8cc000
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.792655] PC is at watchdog_timer_fn+0x230/0x33c
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.797439] LR is at watchdog_timer_fn+0x230/0x33c
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.802225] pc : [] lr : [] pstate: 600001c5
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.809603] sp : ffffffc1ec8cfb30
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.812910] x29: ffffffc1ec8cfb30 x28: 0000000000000003
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.818227] x27: ffffffc0010bdb30 x26: ffffffc1f5fc2278
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.823545] x25: ffffffc00108d2d8 x24: ffffffc1ec8cfdd0
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.828863] x23: 0000000000000000 x22: 00000000000006e2
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.834183] x21: ffffffc0010bd000 x20: ffffffc00108d000
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.839501] x19: ffffffc00108d260 x18: ffffffc000adfbc0
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.844818] x17: 000000000000000e x16: 0000000000000007
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.850135] x15: 00000000efe4b99a x14: 0000000000000000
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.855450] x13: 00000000efe4b99a x12: 0000000000000000
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.860767] x11: 0000000000000400 x10: 0000000000010002
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.866085] x9 : 00000000000006d4 x8 : 0000000000000000
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.871403] x7 : ffffffc0010bc9c8 x6 : ffffffc0010d1fd8
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.876718] x5 : ffffffc0002887c0 x4 : 0000000000000000
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.882038] x3 : 0000000000000000 x2 : 0000000000010001
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.887353] x1 : ffffffc1ec8cc000 x0 : 0000000000000026
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.892671]
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.894736] —[ end trace e539f70082e21a58 ]—
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.899344] Call trace:
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.901790] [] watchdog_timer_fn+0x230/0x33c
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.907619] [] __hrtimer_run_queues+0xf8/0x17c
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.913615] [] hrtimer_interrupt+0x9c/0x1e0
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.919357] [] tegra186_timer_isr+0x24/0x30
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.925096] [] handle_irq_event_percpu+0x60/0x140
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.931351] [] handle_irq_event+0x44/0x74
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.936915] [] handle_fasteoi_irq+0xb4/0x188
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.942738] [] generic_handle_irq+0x24/0x38
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.948472] [] __handle_domain_irq+0x60/0xb4
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.954295] [] gic_handle_irq+0x5c/0xb4
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.959685] [] el1_irq+0x80/0xf8
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.964470] [] cpuidle_enter+0x18/0x20
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.969813] [] call_cpuidle+0x28/0x50
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.975040] [] cpu_startup_entry+0x150/0x21c
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.980863] [] secondary_start_kernel+0x12c/0x164
Jul 28 23:03:54 tegra-ubuntu kernel: [ 1896.987118] [<0000000080081acc>] 0x80081acc
Jul 28 23:04:53 tegra-ubuntu kernel: [ 1955.466090] INFO: rcu_preempt detected stalls on CPUs/tasks:
Jul 28 23:04:53 tegra-ubuntu kernel: [ 1955.471757] 3-…: (1 GPs behind) idle=63b/140000000000000/0 softirq=297836/297837 fqs=19326
Jul 28 23:04:53 tegra-ubuntu kernel: [ 1955.480351] (detected by 4, t=21010 jiffies, g=164238, c=164237, q=17892)
Jul 28 23:04:53 tegra-ubuntu kernel: [ 1955.487220] Task dump for CPU 3:
Jul 28 23:04:53 tegra-ubuntu kernel: [ 1955.490438] systemd-journal R running task 0 293 1 0x00000002
Jul 28 23:04:53 tegra-ubuntu kernel: [ 1955.497489] Call trace:
Jul 28 23:04:53 tegra-ubuntu kernel: [ 1955.499935] [] __switch_to+0xa4/0xb0
Jul 28 23:04:53 tegra-ubuntu kernel: [ 1955.505060] [] 0xffffffc1e09c7e80
