I’m trying to use the bmi088 kernel driver on a Orin Nano with kernel 5.10.120 (L4T 35.4.1).
The BMI088 is connected to i2c-0 with the accelerometer at 0x19 and gyroscope at 0x68.
INT1 is connected to PAA.00 and INT3 to PAA.01.
My device tree looks like this:
i2c@3160000 { /* i2c0 */
bmi088@68 {
compatible = "bmi,bmi088";
status = "okay";
reg = <0x68>;
accel_i2c_addr = <0x19>;
accel_irq_gpio = <&tegra_aon_gpio TEGRA234_AON_GPIO(AA, 0) GPIO_ACTIVE_HIGH>;
gyro_irq_gpio = <&tegra_aon_gpio TEGRA234_AON_GPIO(AA, 1) GPIO_ACTIVE_HIGH>;
accel_matrix = [01 00 00 00 01 00 00 00 01];
gyro_matrix = [01 00 00 00 01 00 00 00 01];
accel_reg_0x53 = <0x0A>; /* INT1 output active high */
gyro_reg_0x16 = <0x01>; /* INT3 output active high */
gyro_reg_0x18 = <0x01>; /* INT3 as data-ready interrupt */
with the pinmux config
can0_dout_paa0 {
nvidia,pins = "can0_dout_paa0";
nvidia,function = "rsvd1";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_ENABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
can0_din_paa1 {
nvidia,pins = "can0_din_paa1";
gpio-defaults:
gpio@c2f0000 {
gpio-init-names = "default";
gpio-init-0 = <&gpio_aon_default>;
gpio_aon_default: default {
gpio-input = <
TEGRA234_AON_GPIO(EE, 4)
TEGRA234_AON_GPIO(CC, 1)
TEGRA234_AON_GPIO(CC, 2)
TEGRA234_AON_GPIO(CC, 3)
gpio-output-low = <
TEGRA234_AON_GPIO(EE, 2)
TEGRA234_AON_GPIO(CC, 0)
TEGRA234_AON_GPIO(AA, 4)
gpio-output-high = <
TEGRA234_AON_GPIO(AA, 5)
TEGRA234_AON_GPIO(BB, 3)
The bmi088 driver is properly loaded and reports
kernel: [ 19.333464] bmi088 0-0068: iio accelerometer done
kernel: [ 19.352378] bmi088 0-0068: iio gyroscope done
I can also see that the gpio config seems to be ok:
cat /sys/kernel/debug/gpio
gpiochip1: GPIOs 316-347, parent: platform/c2f0000.gpio, tegra234-gpio-aon:
gpio-316 (PAA.00 |accelerometer ) in lo IRQ
gpio-317 (PAA.01 |gyroscope ) in lo IRQ
But when I try to run iio_generic_buffer according to BMI088 IMU Driver — Jetson Linux Developer Guide documentation
I enabled all scan elements except in_timestamp_en and when I then run iio_generic_buffer -c 10 --device-name accelerometer -g I get a kernel panic:
[ 731.200579] Unable to handle kernel NULL pointer dereference at vir8
[ 731.209670] Mem abort info:
[ 731.212586] ESR = 0x96000004
[ 731.215745] EC = 0x25: DABT (current EL), IL = 32 bits
[ 731.221213] SET = 0, FnV = 0
[ 731.224363] EA = 0, S1PTW = 0
[ 731.227604] Data abort info:
[ 731.230565] ISV = 0, ISS = 0x00000004
[ 731.234515] CM = 0, WnR = 0
[ 731.237565] user pgtable: 4k pages, 48-bit VAs, pgdp=00000001311eb000
[ 731.244207] [0000000000000028] pgd=0000000000000000, p4d=0000000000000000
[ 731.251215] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 731.256963] Modules linked in: xt_MASQUERADE nf_conntrack_netlink nfnetlink iptable_nat nf_nat br_netk
[ 731.257058] nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c ip6table_filter ip6_tables nvmap iptable_filter ]
[ 731.362042] CPU: 3 PID: 10357 Comm: iio_generic_buf Not tainted 5.10.120-tegra #1
[ 731.369710] Hardware name: Unknown NVIDIA Orin Nano Developer Kit/NVIDIA Orin Nano Developer Kit, BIO3
[ 731.381402] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=--)
[ 731.387574] pc : _raw_spin_lock+0x44/0x90
[ 731.391683] lr : _raw_spin_lock+0x1c/0x90
[ 731.395795] sp : ffff8000153939d0
[ 731.399194] x29: ffff8000153939d0 x28: 0000000000000001
[ 731.404635] x27: ffffa7285a72a910 x26: ffffa7285a729290
[ 731.410086] x25: ffffa7285a72a8b0 x24: ffffa7285a7290c0
[ 731.415538] x23: ffffa7285a72a8d0 x22: 0000000000000060
[ 731.420979] x21: 0000000000000018 x20: ffffa7285a728ee8
[ 731.426423] x19: 0000000000000028 x18: 0000000000000001
[ 731.431876] x17: 0000000000000000 x16: ffffa728595c8750
[ 731.437331] x15: ffff62f2ea058570 x14: ffffffffffffffff
[ 731.442777] x13: ffff62f2f1a41188 x12: 0000000000000010
[ 731.448218] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 731.453665] x9 : 6d6475645e6c746d x8 : 7f7f7f7f7f7f7f7f
[ 731.459119] x7 : fefefefefeff7273 x6 : 0000808080808080
[ 731.464565] x5 : 8080808080800000 x4 : 0000000000000000
[ 731.470006] x3 : 0000000000000000 x2 : 0000000000000001
[ 731.475452] x1 : 0000000000000000 x0 : 0000000000000028
[ 731.480902] Call trace:
[ 731.483415] _raw_spin_lock+0x44/0x90
[ 731.487170] __gte_register_event+0x150/0x340
[ 731.491638] tegra_gte_register_event+0x8c/0xe0
[ 731.496292] bmi_gte_init+0x58/0x70 [bmi088]
[ 731.500668] bmi_enable+0x5c/0x3e0 [bmi088]
[ 731.504954] bmi_iio_buffer_postenable+0x50/0xb8 [bmi088]
[ 731.510493] __iio_update_buffers+0x598/0x830
[ 731.514958] iio_buffer_store_enable+0x90/0x100
[ 731.519603] dev_attr_store+0x48/0x60
[ 731.523353] sysfs_kf_write+0x60/0x70
[ 731.527100] kernfs_fop_write_iter+0x12c/0x1c0
[ 731.531651] new_sync_write+0xfc/0x1a0
[ 731.535498] vfs_write+0x25c/0x390
[ 731.538981] ksys_write+0x7c/0x110
[ 731.542466] __arm64_sys_write+0x28/0x40
[ 731.546485] el0_svc_common.constprop.0+0x80/0x1d0
[ 731.551401] do_el0_svc+0x38/0xb0
[ 731.554811] el0_svc+0x1c/0x30
[ 731.557942] el0_sync_handler+0xa8/0xb0
[ 731.561871] el0_sync+0x16c/0x180
[ 731.565268] Code: 52800001 aa1303e0 52800022 2a0103e3 (88e37e62)
[ 731.571520] ---[ end trace 386a7cde7cd53105 ]---
[ 731.581243] Kernel panic - not syncing: Oops: Fatal exception
[ 731.587138] SMP: stopping secondary CPUs
[ 731.591162] Kernel Offset: 0x2728487a0000 from 0xffff800010000000
[ 731.597404] PHYS_OFFSET: 0xffff9d0e40000000
[ 731.601687] CPU features: 0x08040006,4a80aa38
[ 731.606151] Memory Limit: none
[ 731.614239] ---[ end Kernel panic - not syncing: Oops: Fatal exception ]---
Any pointer are much appreciated!
