Hi NV,
we hit kernel panic issue when suspend/resume stress,
log looks like GPU or HDMI issue,
colud you help to clarify it?
thanks.
[ 5683.889505] nvidia-modeset: ERROR: GPU:0: Failed detecting connected display devices
[ 5683.889777] nvidia-modeset: ERROR: GPU:0: Failure reading maximum pixel clock value for display device HDMI-0.
panic.log (46.2 KB)
Is this issue able to reproduce with NV devkit? For HDMI, need to use p3509 (xavier nx devkit carrier board). For DP, need to use orin nano devkit.
zax
May 11, 2023, 9:08am
4
I have encountered the same issue
I’ve tried the p3509 and it still showed the dce-fabric error, but no kernel panic
The suspend and resume function is ok
suspend.txt (9.9 KB)
This topic only discuss about the panic case.
zax
May 11, 2023, 9:14am
6
Yes, I mean I also encounter the panic issue on our custom board
kernelpanic.txt (5.1 KB)
And I tried to reproduce on xavier nx devkit carrier board, but it can’t reproduce
Do you have full log of your custom board log to share? Full log means starting from power up.
zax
May 11, 2023, 9:25am
8
Here’s full log
log.txt (92.9 KB)
What does your device tree look like? Is it based on 3768 device tree? What did you change there?
zax
May 11, 2023, 9:38am
10
Yes, it is base on p3768 device tree
I have changed usb related because we have some usb3 and use micro usb for flash port instead of type-c
add a new com port for serial@3110000
I also modified the display for hpd
display@13800000 {
I modified the display source for hdmi in tegra234-p3767-0000-p3768-0000-a0.dts(I know it is for Orin NX 16GB, but Orin NANO will include this file, so I modified here)
+//#include “tegra234-dcb-p3767-0000-dp.dtsi”
+#include “tegra234-dcb-p3767-0000-hdmi.dtsi”
and I also modified the pinmux in p3768-0000+p3767-0000.conf from DP to HDMI
What is your method to update the device tree?
zax
May 11, 2023, 9:43am
12
modified all dts and build, then copy to the l4t/kernel/dtb, then flash by command in document
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/IN/QuickStart.html
Does this issue happen with specific monitor or every monitor can hit it?
zax
May 11, 2023, 10:01am
14
Hi
I changed another monitor, and it didn’t show kernel panic but stuck at
��[ 202.468270] Camera-FW on t234-rce-safe started
TCU early console enabled.
[ 202.579495] Camera-FW on t234-rce-safe ready SHA1=97e50cbf (crt 1.260 ms, total boot 112.585 ms)
and it reboot a few minutes later
Is it also “resume” case?
zax
May 11, 2023, 10:03am
16
No it is suspend case, it seems can not suspend normally
So it can boot up if no monitor is connected?
zax
May 11, 2023, 10:13am
18
Yes, it can
log_without_hdmi.txt (86.6 KB)
There is not much to check on Orin display.
If you are sure the pinmux, dcb and device tree are all correct, then you can only check the hardware.
For example, this error log “Failed detecting connected display devices” is due to connected state of the HDMI monitor cannot be detected correctly.
zax
May 12, 2023, 1:46am
20
Thanks, I will check hardware with our EE
What kinds of issue maybe related?
zax
May 18, 2023, 3:12am
21
(update)
Sorry for my mistake
That is a resume case
The reason is because we use B key nvme ssd for boot storage
But B key storage has no suspend clock pin for waking up
So it will stuck and it will resume rarely
