[Orin NX 8G]display blank and with GPU error when resume
Hi NV,
we encounter a gpu issue when resume on Jetpack 6.1,
GPU print error log and display blank when resume, then system hang,
more detail log as attachment,
Jetpack 6.0 without this issue,
please help to clarify,
thanks.
putty6.log (35.5 KB)
Hi NV,
we also can reproduce this issue on NV reference board,
log as attachment,
thanks,
putty9.log (183.6 KB)
Hi bross_kuo,
We notice the same issue and had a fix in below DCE firmware and kernel dtst patch.
Please try them on your side. Thanks.
kernel patch:
diff --git a/nv-platform/tegra234-p3768-0000+p3767-xxxx-nv-common.dtsi b/nv-platform/tegra234-p3768-0000+p3767-xxxx-nv-common.dtsi
index f2c048a..3f68f82 100644
--- a/nv-platform/tegra234-p3768-0000+p3767-xxxx-nv-common.dtsi
+++ b/nv-platform/tegra234-p3768-0000+p3767-xxxx-nv-common.dtsi
@@ -429,3 +429,5 @@
 		status = "okay";
+/delete-node/ &{/gpio-keys/key-suspend};
dce fw:
dce-r364.bin (11.3 MB)
Hi Wayne,
I can’t find dce-r364.bin in source code folder, how to replace it?
if this modification will include in next SDK release ,
could you give us the patch?
thanks.
DCE firmware is not open source. You can only replace the binary into Linux_for_Tegra/bootloader/display-t234-dce.bin and must do full flash.
Hi Wayne,
understood, it work for this issue,
but we reproduce another bug,
when device is suspending and kernel log show “DCE RM Suspend rmStatus:0x0”,
trigger interrupt continually, for example: move mouse continually,
system is very easy to panic, hit rate is about 20%,
thanks.
[ 746.502259] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000070
[ 746.502265] Mem abort info:
[ 746.502265] ESR = 0x0000000096000004
[ 746.502267] EC = 0x25: DABT (current EL), IL = 32 bits
[ 746.502269] SET = 0, FnV = 0
[ 746.502269] EA = 0, S1PTW = 0
[ 746.502270] FSC = 0x04: level 0 translation fault
[ 746.502271] Data abort info:
[ 746.502272] ISV = 0, ISS = 0x00000004
[ 746.502273] CM = 0, WnR = 0
[ 746.502274] user pgtable: 4k pages, 48-bit VAs, pgdp=000000012a253000
[ 746.502276] [0000000000000070] pgd=0000000000000000, p4d=0000000000000000
[ 746.502281] Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP
[ 746.502284] Modules linked in: nvidia_drm(OE) nvidia_modeset(OE) lzo_rle lzo_compress zram zsmalloc nvme_fabrics ramoops reed_solomon bridge stp llc usb_f_ncm usb_f_mass_storage usb_f_acm u_serial usb_f_rndis u_ether libcomposite snd_soc_tegra210_admaif(O) snd_soc_tegra_utils(O) snd_soc_tegra_pcm snd_soc_tegra186_asrc(O) snd_soc_tegra210_mixer(O) snd_soc_simple_card_utils snd_soc_tegra186_arad(O) snd_soc_tegra210_afc(O) snd_soc_tegra210_dmic(O) snd_soc_tegra210_i2s(O) snd_soc_tegra210_ope(O) snd_soc_tegra210_mvc(O) snd_soc_tegra186_dspk(O) snd_soc_tegra210_sfc(O) snd_soc_tegra210_amx(O) snd_soc_tegra210_adx(O) r8153_ecm cdc_ether usbnet tegra210_adma spidev snd_soc_tegra210_ahub(O) nvvrs_pseq_rtc(O) crct10dif_ce r8152 tegra234_oc_event(O) mttcan(O) nvpps(O) nvpmodel_clk_cap(O) can_dev thermal_trip_event(O) tegra_cactmon_mc_all(O) joydev snd_hda_codec_hdmi tegra234_aon(O) tegra_aconnect at24 snd_hda_tegra snd_hda_codec pwm_tegra_tachometer(O) r8168(O) snd_hda_core mc_hwpm(O) nvidia(OE)
[ 746.502347] spi_tegra114 nv_imx219(O) tegra_pcie_dma_test(O) tegra_pcie_edma(O) nvidia_vrs_pseq(O) tegra_dce(O) host1x_fence(O) tsecriscv(O) nvhost_vi5(O) nvhost_isp5(O) nvhost_nvcsi_t194(O) tegra_camera(O) v4l2_dv_timings nvhost_nvcsi(O) tegra_camera_platform(O) capture_ivc(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) ivc_ext(O) v4l2_fwnode v4l2_async governor_userspace videobuf2_dma_contig videobuf2_memops tegra_drm(O) videobuf2_v4l2 videobuf2_common nvhost_pva(O) nvhost_nvdla(O) tegra_wmark(O) nvhost_capture(O) videodev cec mc drm_kms_helper nvhwpm(O) host1x_nvhost(O) nvidia_p2p(O) ina3221 nvgpu(O) governor_pod_scaling(O) host1x(O) mc_utils(O) nvmap(O) nvsciipc(O) rtk_btusb(O) fuse drm ip_tables x_tables ipv6 pwm_fan(E) pwm_tegra(E) tegra_bpmp_thermal(E) tegra_xudc(E) ucsi_ccg(E) typec_ucsi(E) typec(E) nvme(E) nvme_core(E)
[ 746.502407] CPU: 2 PID: 1499 Comm: Xorg Tainted: G OE 5.15.148-tegra #1
[ 746.502410] Hardware name: NVIDIA ASUS PE1100N/ORIN NX 8G/JONXS-IM-A 8G/Jetson, BIOS 36.4.0-gcid-37537400 09/13/2024
[ 746.502412] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=–)
[ 746.502415] pc : nvCtxDmaBind+0x1c/0x230 [nvidia_modeset]
[ 746.502493] lr : nvRmAllocAndBindSurfaceDescriptor+0x70/0x130 [nvidia_modeset]
[ 746.502548] sp : ffff80000bdabb00
[ 746.502549] x29: ffff80000bdabd30 x28: ffff0000b8f25f08 x27: 0000000000000008
[ 746.502552] x26: ffff0000b8f25008 x25: ffff000097365028 x24: ffff000097365008
[ 746.502555] x23: ffff0000b8f25014 x22: ffff0000a7ada008 x21: ffff0000a7ada008
[ 746.502557] x20: 0000000000000000 x19: ffff0000a7ada008 x18: ffffceceb4a8ce20
[ 746.502559] x17: ffffceceb4a8ce30 x16: ffffcecef6151d80 x15: ffff00008b8ebb68
[ 746.502561] x14: 0000000000000068 x13: 00000000000000c0 x12: 0000000000000068
[ 746.502563] x11: ffff0001f12ef8b8 x10: ffff80000bdab840 x9 : 00000000ffffffe8
[ 746.502565] x8 : ffff80000bdab820 x7 : 0000000000000000 x6 : ffffceceb4b8d000
[ 746.502567] x5 : 0000000000000001 x4 : 0000000000000004 x3 : 0000000000000009
[ 746.502570] x2 : 0000000000000009 x1 : 0000000000000000 x0 : 00000000c1d00000
[ 746.502572] Call trace:
[ 746.502574] nvCtxDmaBind+0x1c/0x230 [nvidia_modeset]
[ 746.502628] nvidia_frontend_unlocked_ioctl+0x60/0x80 [nvidia]
[ 746.502726] __arm64_sys_ioctl+0xb4/0x100
[ 746.502733] invoke_syscall+0x5c/0x130
[ 746.502740] el0_svc_common.constprop.0+0x64/0x110
[ 746.502743] do_el0_svc+0x74/0xa0
[ 746.502745] el0_svc+0x28/0x80
[ 746.502752] el0t_64_sync_handler+0xa4/0x130
[ 746.502754] el0t_64_sync+0x1a4/0x1a8
[ 746.502758] Code: f9002bfe 2a0203e3 b9490000 52800084 (b9407025)
[ 746.502763] —[ end trace 2162662de7169525 ]—
[ 746.508088] PM: suspend exit
nv_modeset_panic_20241120.log (33.1 KB)
Hi Wayne,
this issue should not cause your modification,
Jetpack 6.1 already has this issue,
thanks.
Hi @bross_kuo
Please file a separate topic. I think that one is something unknown.
