Orin nano cannot suspend resuume (JP 6.1 r36.4.2, SKU 0005)
I tested orin nano devkit cannot suspend and resume successfully. The OS is flashed by SDKManager.
Then I clicked the suspend button to have devkit in suspend mode. And tried to make it resume. But it doesn’t work.
Here is a debug message
debug_uart.log (174.9 KB)
Is it a bug with suspend function?
Hi ruei_chang,
Please share the result of the following command on your board.
$ cat /etc/nv_tegra_release
How did you resume the devkit?
From the log you shared, it seems suspend/resume working as expected.
	Line 3860: ÿèDCE RM Suspend rmStatus:0x0
	Line 4249: ÿèDCE RM resume rmStatus:0x0 ret:true
	Line 4671: ÿèDCE RM Suspend rmStatus:0x0
	Line 5055: ÿèDCE RM resume rmStatus:0x0 ret:true
Please also verify with the latest Jetpack 6.2(L4T r36.4.3).
I use the DP to HDMI dongle. I’m not able to see the display resume…
Also I tested the JP 6.2(r36.4.3). The JP 6.2 is okay. Will operate devkit with JP6.2
