I used 35.4.1 on Orin Nano 4gb with Xavier NX board and I found that it cannot suspend.
The DUT will be reboot after the command: sudo systemctl suspend.
Could you please check this issue? Thank you a lot.
The command I used to build:
sudo BOARDID=3767 BOARDSKU=0004 ./tools/kernel_flash/l4t_initrd_flash.sh --massflash 10 --no-flash --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 p3509-a02+p3767-0000 internal
The file I modified in order to build, flash, boot up successfully: tegra234-mb2-bct-scr-p3767-0000.dts
Hi @WayneWWW ,
I have your patch and run suspend-resume test. About 114 times, the device just reboot, instead of suspend.
使用您的patch,效果有好。但是,我們在測試suspend-resume test時,約莫114次發生重新開機的現象,並沒有suspend下去。
以下是擷取的logs:
