The limit of the Nvidia API is 40 requests per minute, but when operating at a scale of 2.6 it works correctly at first and then a “Too Many Requests (429)” error appears. Even after waiting 5 minutes the same issue reoccurs. Has NVIDIA set a hidden limit? How can this problem be fixed?
Hey, sort of unrelated (sorry!!) but does Kimi K2.6 Reason/Think for you?
we dont know yet wait for mod or admin to reply
Related topics
| Issue with 429 errors on NVIDIA NIM despite low usage | 1 | 840 | August 15, 2026 | |
| I got rate limit error every time I use Nvidia NIM API | 1 | 2031 | July 4, 2026 | |
| Kimi K2.6 is rate limited to 30 requests per hour | 5 | 1123 | May 10, 2026 | |
| API Error 429 : Help | 47 | 4798 | August 26, 2026 | |
| Kimi K2.5 is Unusable via API Most of the Time | 1 | 1796 | February 2, 2026 | |
| 尊敬的支持团队: 我正在使用 NVIDIA NIM API 进行个人开发/测试。由于进行多智能体(Agentic Workflow)开发,单次任务会产生20-50次API调用环节,导致频繁遇到 429 Too Many Requests 错误,严重影响了开发进度。特此申请将速率限制从当前的 40 | 0 | 105 | August 28, 2026 | |
| 申请提高 NIM API 速率限制(40 → 200 RPM) | 0 | 516 | May 7, 2026 | |
| Request to increase NIM API rate limit (40 → 200 RPM) for my personal account | 1 | 234 | May 11, 2026 | |
| 申请提高 NIM API 速率限制(40 → 200 RPM) | 0 | 166 | May 22, 2026 | |
| Continuous HTTP 429 (Too Many Requests) on single API calls even with newly generated keys | 1 | 1007 | July 19, 2026 |
