Setup details:
MT9M021 camera chip connected through i2c-mipi converter to CSI port A.
Our kernel is based on L4T 28.1.
Though I am able to capture images using v4l2-ctl as well as yavta, I am not able to use argus to obtain image captures from my MT9M021 camera. I observe error prints while attempting to open argus_camera. Can you please help us figure out the issue that we are facing with Argus.
According to the compliance test, there are no failures:
ubuntu@tegra-ubuntu:~$ v4l2-compliance -d /dev/video0
Driver Info:
Driver name : tegra-video
Card type : vi-output, mt9m021 6-0010
Bus info : platform:54080000.vi:0
Driver version: 4.4.38
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second video open: OK
test VIDIOC_G/S_PRIORITY: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Test input 0:
Control ioctls:
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 9 Private Controls: 14
Format ioctls:
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
test VIDIOC_G/S_PARM: OK (Not Supported)
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
test VIDIOC_S_FMT: OK
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
fail: v4l2-test-formats.cpp(1486): node->can_scale && node->frmsizes_count[v4l_format_g_pixelformat(&cur)]
test Scaling: OK
Codec ioctls:
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls:
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
test VIDIOC_EXPBUF: OK
Test input 0:
Total: 42, Succeeded: 42, Failed: 0, Warnings: 0
But when I run argus using the following command:
argus_camera --device=0
The GUI opens and shows settings but doesn’t show any camera stream.
Here are the terminal prints:
ubuntu@tegra-ubuntu:~$ argus_camera --device=0
Executing Argus Sample Application (argus_camera)
Argus Version: 0.96.2 (multi-process)
Error generated. /home/ubuntu/argus/argus/samples/utils/EGLGlobal.cpp, initialize:97 Could not initialize EGL display
Error generated. /home/ubuntu/argus/argus/apps/camera/renderer/Composer.cpp, initialize:92 (propagating)
Error generated. /home/ubuntu/argus/argus/apps/camera/renderer/Composer.cpp, getInstance:78 Initalization failed
(Argus) Error NotSupported: Failed to initialize EGLDisplay (in src/eglutils/EGLUtils.cpp, function getDefaultDisplay(), line 75)
Error generated. /home/ubuntu/argus/argus/apps/camera/renderer/Composer.cpp, bindStream:132 Invalid stream
Error generated. /home/ubuntu/argus/argus/apps/camera/modules/tasks/StillCapture.cpp, start:132 (propagating)
Error generated. /home/ubuntu/argus/argus/apps/camera/ui/capture/AppModuleCapture.cpp, start:154 (propagating)
Error generated. /home/ubuntu/argus/argus/apps/camera/ui/camera/Main.cpp, onModuleChanged:344 (propagating)
Error generated. /home/ubuntu/argus/argus/samples/utils/Observed.cpp, registerObserver:62 (propagating)
Error generated. /home/ubuntu/argus/argus/apps/camera/ui/camera/Main.cpp, start:282 (propagating)
Here are the prints from dmesg:
[ +0.017319] mt9m021 6-0010: mt9m021_power_off: power off
[Nov 6 12:56] mt9m021 6-0010: mt9m021_power_on: power on
[ +0.016117] mt9m021 6-0010: mt9m021_power_off: power off
[ +0.014293] mt9m021 0-0010: mt9m021_power_on: power on
[ +0.013657] mt9m021 0-0010: mt9m021_power_off: power off
[ +0.015836] mt9m021 6-0010: mt9m021_power_on: power on
[ +0.016238] mt9m021 6-0010: mt9m021_power_off: power off
[ +0.015005] mt9m021 0-0010: mt9m021_power_on: power on
[ +0.013142] mt9m021 0-0010: mt9m021_power_off: power off
[ +0.066524] mt9m021 0-0010: mt9m021_power_on: power on
[ +0.013350] mt9m021 0-0010: mt9m021_power_off: power off
[ +0.014254] mt9m021 0-0010: mt9m021_power_on: power on
[ +0.013703] mt9m021 0-0010: mt9m021_power_off: power off
[ +0.014286] mt9m021 0-0010: mt9m021_power_on: power on
[ +0.013703] mt9m021 0-0010: mt9m021_g_input_status
[ +0.004817] mt9m021 0-0010: mt9m021_power_off: power off
[ +0.024384] mt9m021 0-0010: mt9m021_power_on: power on
[ +0.014816] mt9m021 0-0010: mt9m021_power_off: power off
[ +0.014357] mt9m021 6-0010: mt9m021_power_on: power on
[ +0.013633] mt9m021 6-0010: mt9m021_power_off: power off
[ +0.014430] mt9m021 6-0010: mt9m021_power_on: power on
[ +0.013740] mt9m021 6-0010: mt9m021_power_off: power off
[ +0.014279] mt9m021 6-0010: mt9m021_power_on: power on
[ +0.013733] mt9m021 6-0010: mt9m021_g_input_status
[ +0.004980] mt9m021 6-0010: mt9m021_power_off: power off
Following is the instantiation of cameera in my dtsi:
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
#define CAM0_RST TEGRA_GPIO(S, 4)
#define CAM1_RST TEGRA_GPIO(S, 5)
#define CAM0_PWDN TEGRA_GPIO(S, 7)
#define CAM1_PWDN TEGRA_GPIO(T, 0)
I2C Busses:
i2c0 = "/i2c@7000c000";
i2c1 = "/i2c@7000c400";
i2c2 = "/i2c@7000c500";
i2c3 = "/i2c@7000c700";
i2c4 = "/i2c@7000d000";
i2c5 = "/i2c@7000d100";
i2c6 = "/host1x/i2c@546c0000";
i2c@7000c000 {
status = "okay";
#address-cells = <1>;
#size-cells = <0>;
mt9m021_b@10 {
compatible = "nvidia,mt9m021";
/* I2C device address */
reg = <0x10>;
/* Physical dimensions of sensor */
physical_w = "10";
physical_h = "10";
/* Sensor Model */
sensor_model ="mt9m021";
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
post_crop_frame_drop = "0";
/* when set true analog gain value expressed in decibels." */
use_decibel_gain = "false";
/* if true, delay gain setting by one frame to be in sync with exposure */
delayed_gain = "true";
/* enable CID_SENSOR_MODE_ID for sensor modes selection */
use_sensor_mode_id = "true";
/* slave or master mode */
trigger_mode = "master";
/* Device */
devnode = "video1";
/* input clock for the device in MHz*/
clocks = <&tegra_car TEGRA210_CLK_CLK_OUT_3>;
clock-names = "clk_out_3";
clock-frequency = <24000000>;
mclk = "clk_out_3";
reset-gpios = <&gpio CAM1_RST GPIO_ACTIVE_HIGH>;
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
vana-supply = <&battery_reg>; // analog 2.8v
vif-supply = <&battery_reg>; // interface 1.8v
vdig-supply = <&battery_reg>; // digital 1.2v
avdd-reg = "vana";
iovdd-reg = "vana";
dvdd-reg = "vana";
has-eeprom = <0>;
mode0 {
mclk_khz = "24000";
num_lanes = "1";
tegra_sinterface = "serial_b";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1280";
active_h = "720";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type="bayer";
pixel_phase="rggb";
pixel_t = "bayer_rggb12";
readout_orientation = "0";
line_length = "1650";
inherent_gain = "1";
mclk_multiplier = "3.094";
pix_clk_hz = "74250000";
min_gain_val = "4";
max_gain_val = "3200";
min_hdr_ratio = "";
max_hdr_ratio = "";
min_framerate = "1";
max_framerate = "60";
min_exp_time = "1";
max_exp_time = "0xffff";
embedded_metadata_height = "0";
ports {
#address-cells = <0x1>;
#size-cells = <0x0>;
port@0 {
reg = <0x0>;
mt9m021_slave: endpoint {
csi-port = <0x1>;
bus-width = <0x1>;
remote-endpoint = <&mt9m021_slave_nvcsi_port0>;
host1x {
i2c@546c0000 {
status = "okay";
#size-cells = <0>;
mt9m021_a@10 {
reg = <0x10>;
physical_w = "10";
physical_h = "10";
/* Sensor Model */
/* if trae, delay gain setting by one frame to be in sync with exposure */
/* Device */
devnode = "video0";
mclk = "clk_out_3";
reset-gpios = <&gpio CAM0_RST GPIO_ACTIVE_HIGH>;
avdd-reg = "vana";
iovdd-reg = "vana";
dvdd-reg = "vana";
has-eeprom = <0>;
mode0 {
mclk_khz = "24000";
num_lanes = "1";
active_w = "1280";
active_h = "720";
min_gain_val = "4";
min_hdr_ratio = "";
max_hdr_ratio = "";
min_exp_time = "1";
ports {
port@0 {
reg = <0x0>;
mt9m021_master: endpoint {
csi-port = <0x0>;
bus-width = <0x1>;
remote-endpoint = <&mt9m021_master_nvcsi_port0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <0x4>;
modules {
module0 {
status = "okay";
badge = "mt9m021_master";
position = "front";
orientation = "1";
drivernode0 {
status = "okay";
pcl_id = "v4l2_sensor";
devname = "mt9m021 6-0010";
proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/mt9m021_a@10";
module1 {
status = "okay";
badge = "mt9m021_slave";
position = "rear";
orientation = "1";
drivernode0 {
status = "okay";
devname = "mt9m021 0-0010";
proc-device-tree = "/proc/device-tree/i2c@7000c000/mt9m021_b@10";
