L4T/DeepStream Mapping
I am wondering if anyone can help me.
We are developing on Jetson Orin Nano Developer Kit and we are using JetPack 6.1. We require clarification on the following:-
  • L4T/DeepStream Mapping: we are looking for confirmation that DeepStream 7.1 is the intended stable version for JetPack 6.1? We are seeing conflicting info regarding SDK 8.0 (which appears to require JetPack 7.0/Thor). Can you please confirm?
  • Python Service Maker: Are you able to provide what the installation steps are for the Python Service Maker API for DeepStream 7.1? We need to confirm what the PYTHONPATH requirements and if there are specific .deb packages we must fetch manually to enable Service Maker on Orin?
  1. please refer to the Compatibility table, DeepStream 7.1 requires 6.1 GA. DS8.0 only supports Thor.
  2. plese refer to the guide for how to install Python Service Maker.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
