I’m using L4T34.1.1 on Xavier NX.
The UEFI boot fail sometimes. Maybe 1/50. It’s a random issue.
Is it a know issue on JetPack 5.0.1 DP?
This is the log of uefi.
JetPack5.0.1DP_UEFI_boot fail…txt (12.5 KB)
[ 30.216195] nvidia: loading out-of-tree module taints kernel.
[ 81.180887] nvgpu: 17000000.gv11b nvgpu_timeout_expired_msg_cpu:112 [ERR] Timeout detected @ 0000000077ba254b
[ 81.181213] nvgpu: 17000000.gv11b ▒▒▒
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 2.2.0.0-t194-41334769-3540ffaa)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Platform: Silicon
[0000.045] I> Chip revision : A02P
[0000.048] I> Bootrom patch version : 15 (correctly patched)
[0000.053] I> ATE fuse revision : 0x200
[0000.056] I> Ram repair fuse : 0x0
[0000.060] I> Ram Code : 0x0
[0000.062] I> rst_source: 0xb, rst_level: 0x1
[0000.067] I> Boot-device: QSPI (instance: 0)
[0000.071] I> Qspi flash params source = brbct
[0000.075] I> Qspi using bpmp-dma
[0000.078] I> Qspi clock source : pllp
[0000.081] I> QSPI Flash Size = 32 MB
[0000.085] I> Qspi initialized successfully
[0000.088] I> Boot chain mechanism: A/B
[0000.092] I> Current Boot-Chain Slot: 0
[0000.096] W> No valid slot number is found in scratch register
[0000.101] W> Return default slot: _a
[0000.104] I> Qspi flash params source = brbct
[0000.111] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.116] I> Temperature = 44000
[0000.119] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.124] W> Skipping boost for clk: BPMP_APB
[0000.128] W> Skipping boost for clk: AXI_CBB
[0000.132] W> Skipping boost for clk: AON_CPU_NIC
[0000.136] W> Skipping boost for clk: CAN1
[0000.140] W> Skipping boost for clk: CAN2
[0000.144] I> Boot-device: QSPI (instance: 0)
[0000.148] I> Qspi flash params source = mb1bct
[0000.152] I> Qspi using bpmp-dma
[0000.155] I> Qspi clock source : pllc_out0
[0000.159] I> Qspi reinitialized
[0000.162] I> Qspi flash params source = mb1bct
[0000.175] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.182] W> Thermal config not found in BCT
[0000.190] W> MEMIO rail config not found in BCT
[0000.200] I> Qspi flash params source = mb1bct
[0000.213] I> Qspi flash params source = mb1bct
[0000.247] I> Qspi flash params source = mb1bct
[0000.811] I> Qspi flash params source = mb1bct
[0000.828] I> Qspi flash params source = mb1bct
[0000.861] W> Platform config not found in BCT
[0000.888] I> Qspi flash params source = mb1bct
[0000.914] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
[0000.923] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-f46b9673)
[0000.923] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.924] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.925] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.930] W> device prod register failed
[0000.934] I> Boot_device: QSPI_FLASH instance: 0
[0000.939] I> qspi flash-0 params source = boot args
[0000.944] I> QSPI-0l initialized successfully
[0000.948] I> sdmmc-3 params source = safe params
[0001.274] I> sdmmc DDR50 mode
[0001.283] I> Found 42 partitions in QSPI_FLASH (instance 0)
[0001.284] W> Cannot find any partition table for 00000003
[0001.285] > PARTITION_MANAGER: Failed to publish partition.
[0001.290] I> Found 19 partitions in SDMMC_USER (instance 3)
[0001.291] W> No valid slot number is found in scratch register
[0001.291] W> Return default slot: _a
[0001.291] I> Active Boot chain : 0
[0001.900] I> Relocating BR-BCT
[0001.902] > DEVICE_PROD: device prod is not initialized.
[0001.927] E> I2C: slave not found in slaves.
[0001.928] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.929] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.930] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.931] E> eeprom: Failed to read I2C slave device
[0001.934] I> Failed to read CVB eeprom data @ AE
[0001.939] I> Retrying CVB eeprom read @ AC ...
[0001.944] E> I2C: slave not found in slaves.
[0001.948] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0001.955] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.961] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0001.970] E> eeprom: Failed to read I2C slave device
[0001.975] I> Failed to read CVB eeprom data @ AC
[0002.174] I> Relocating OP-TEE dtb from: 0x6bfff0f0 to 0x70050000, size: 703
[0002.174] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0002.175] I> [1] START: 0xaf200000, SIZE: 0x18a00000
[0002.175] I> dram_block larger than 80000000
[0002.176] I> [2] START: 0x100000000, SIZE: 0x180000000
[0002.179] I> Setting NS memory ranges to OP-TEE dtb finished.
[0002.280] I> EKB detected (length: 0x410) @ VA:0x52709400
[0002.281] I> Setting EKB blob info to OPTEE dtb finished.
▒▒NOTICE: BL31: v2.5(release):ef8af0b99
NOTICE: BL31: Built : 20:57:59, May 16 2022
I/TC:
bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
▒▒I/TC: No▒▒clk_early initialized
▒▒n-se▒▒mail_early initialized
▒▒cu▒▒fuse initialized
hwwdt initialized
▒▒re ex▒▒t194_ec_get_ec_list: found 45 ecs
▒▒ternal DT ▒▒ec initialized
▒▒f▒▒vmon_setup_monitors: found 3 monitors
vmon initialized
▒▒oun▒▒adc initialized
fmon_populate_monitors: found 73 monitors
▒▒d
▒▒fmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
▒▒I/TC: OP-TEE version: 6f444acf (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue May 17 04:00:18 UTC 2022 ▒▒dvs initialized
▒▒aa▒▒pm initialized
▒▒r▒▒suspend initialized
▒▒ch64▒▒pg_late initialized
▒▒pg_mrq_init initialized
strap initialized
▒▒nvl initialized
▒▒I/TC: ▒▒emc initialized
emc_mrq initialized
▒▒Primary CPU initializing
▒▒clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
clk_dt_late initialized
noc_late initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
avfs_clk_mach_post initialized
avfs_clk_platform_post initialized
cvc_late initialized
regulator_post initialized
rm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ▒▒I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version r34.1-975eef6 built on 2022-05-16T20:58:45-07:00)
Press ESCAPE for boot options ** WARNING: Test Key is used. **
ExtLinuxBoot: Unable to load image: \boot\Image Not Found
L4TLauncher: Unable to boot via extlinux: Not Found
Failed to read disk
Failed to boot kernel:0 partition
>>Start PXE over IPv4.
PXE-E18: Server response timeout.
>>Start PXE over IPv6.
PXE-E16: No valid offer received.
>>Start HTTP Boot over IPv4.
Error: Could not retrieve NBP file size from HTTP server.
Error: Server response timeout.
>>Start HTTP Boot over IPv6.
Error: Unexpected network error.
UEFI Interactive Shell v2.2
EDK II
UEFI v2.70 (EDK II, 0x00010000)
Mapping table
FS1: Alias(s):F1:
MemoryMapped(0xB,0xA0600000,0xA089F877)
FS0: Alias(s):F0:
Fv(49A79A15-8F69-4BE7-A30C-A172F44ABCE7)
FS2: Alias(s):HD2b:;BLK1:
VenHw(1E5A432C-0466-4D31-B009-D4D9239271D3)/MemoryMapped(0xB,0x3460000
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(1,GPT,3100A992-278E-4E89-A786-18345F776A3B,0x
28,0x1C00000)
FS3: Alias(s):HD2s:;BLK10:
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(18,GPT,46BF0AA6-01CE-463E-9935-0A585EBA736C,0
x1D23400,0x20000)
BLK0: Alias(s):
BLK20: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x1)
BLK21: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x2)
BLK12: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(2,GPT,14B3C782-6610-4F42-A014-88395452627D,0x
1C00028,0x20000)
BLK13: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(3,GPT,77015FE7-0182-4B79-926E-222270A4F225,0x
1C20028,0x380)
BLK14: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(4,GPT,065CDCF3-1655-4DA8-8515-6804F8F6914D,0x
1C203A8,0x10458)
BLK15: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(5,GPT,2EDF02E8-A4FC-4CDF-AB4C-7B729DB64915,0x
1C30800,0x1400)
BLK16: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(6,GPT,45755799-0682-455A-8A00-83207DE7AA79,0x
1C31C00,0x80)
BLK17: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(7,GPT,75FB0881-F4BE-4CBD-BCD0-4B3CFB071A0A,0x
1C31C80,0x800)
BLK18: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(8,GPT,244878E3-B2E9-406A-8424-2B7575224955,0x
1C32480,0x800)
BLK19: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(9,GPT,3EF3DA77-AA2B-4943-9599-B310F9A1A753,0x
1C32C80,0x800)
BLK2: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(10,GPT,4886103B-AE35-4A3B-8DF4-09512270873F,0
x1C33480,0xC00)
BLK3: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(11,GPT,25B4AFB8-625F-432C-9214-7A65AB8C112C,0
x1C34080,0x800)
BLK4: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(12,GPT,70D478B4-29D8-49E2-A383-A3799D7BB31F,0
x1C34880,0x20000)
BLK5: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(13,GPT,16C1CED4-D04E-4C1E-BA32-FD346D26375C,0
x1C54880,0x380)
BLK6: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(14,GPT,3178D6D1-3284-4580-AA0D-E25552DF7327,0
x1C54C00,0x10400)
BLK7: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(15,GPT,723E2743-DE26-422D-8DE7-8D3126A08616,0
x1C65000,0x28000)
BLK8: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(16,GPT,2298910F-0B51-46B9-9CC2-CF6B876B8C61,0
x1C8D000,0x400)
BLK9: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(17,GPT,4FFCB57C-5C71-4C83-800D-3435B7C58218,0
x1C8D400,0x96000)
BLK11: Alias(s):
,0x347FFFF)/eMMC(0x0)/Ctrl(0x0)/HD(19,GPT,796A642D-4A6C-4D84-8947-8518E2DC3E6A,0
x1D43400,0x16BDF)
Press ESC in 1 seconds to skip startup.nsh or any other key to continue.
Shell>
