I’m having a problem with the latest Nvidia drivers 358.16 and 361.18.
Please see the linked video:
My monitor is a 4k Television Panasonic TC-58AX800U. Nvidia GPU is an EVGA GTX980. I’m running Arch.
I’ve tried setting modelines and frequency for my monitor, it just simply ignores it completely and continues to have this issue.
I have to revert back to using 352.63 drivers which work perfectly fine and I do not have this issue. I don’t have an xorg config and use whatever Nvidia gives me to work and works fine with 352.63.
Mind you, I’ve even tried to create my own modeline with no success utilizing my own custom xorg.conf
HorizSync 15.0 - 136.0
VertRefresh 23.0 - 61.0
Modeline "3840x2160" 593.41 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync
Modeline "3840x2160" 594.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync
Modeline "1920x1080@60" 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Yes, I’ve tried “UseEdid” to false, disabled all the ModeValidation, nothing works. I’ve tried using the displayport and the problem is even worse. Going back to the 352 drivers, both HDMI and the Displayport work fine.
If this is an Nvidia bug, I hope it’s going to be resolved. If anyone is running into similar problems and has a solution, would love to hear it.
And here’s the funny thing, the new driver does detect the EDID just fine for the monitor. So what the hell?
[ 6084.749] (--) NVIDIA(0): Panasonic-TV (DFP-1): 600.0 MHz maximum pixel clock
[ 6084.749] (--) NVIDIA(0): --- EDID for Panasonic-TV (HDMI-0) ---
[ 6084.749] (--) NVIDIA(0): EDID Version : 1.3
[ 6084.749] (--) NVIDIA(0): Manufacturer : MEI
[ 6084.749] (--) NVIDIA(0): Monitor Name : Panasonic-TV
[ 6084.749] (--) NVIDIA(0): Product ID : 0xa296
[ 6084.749] (--) NVIDIA(0): 32-bit Serial Number : 0x01010101
[ 6084.749] (--) NVIDIA(0): Serial Number String :
[ 6084.749] (--) NVIDIA(0): Manufacture Date : 2014, week 0
[ 6084.749] (--) NVIDIA(0): DPMS Capabilities :
[ 6084.749] (--) NVIDIA(0): Input Type : Digital
[ 6084.749] (--) NVIDIA(0): Prefer first detailed timing : Yes
[ 6084.749] (--) NVIDIA(0): Supports GTF : No
[ 6084.749] (--) NVIDIA(0): Maximum Image Size : 1280 mm x 720 mm
[ 6084.749] (--) NVIDIA(0): Valid HSync Range : 15.0 kHz - 136.0 kHz
[ 6084.749] (--) NVIDIA(0): Valid VRefresh Range : 23.0 Hz - 61.0 Hz
[ 6084.749] (--) NVIDIA(0): EDID maximum pixel clock : 600.0 MHz
[ 6084.749] (--) NVIDIA(0): CEA-861 extension block # : 0
[ 6084.749] (--) NVIDIA(0): CEA-861 revision : 3
[ 6084.749] (--) NVIDIA(0): IEEE Vendor Registration ID: 00-0c-03
[ 6084.749] (--) NVIDIA(0): IEEE Vendor Registration ID: c4-5d-d8
[ 6084.749] (--) NVIDIA(0): Supports YCbCr 4:4:4 : Yes
[ 6084.749] (--) NVIDIA(0): Supports YCbCr 4:2:2 : Yes
[ 6084.749] (--) NVIDIA(0): Supports Basic Audio : Yes
[ 6084.749] (--) NVIDIA(0): Audio Descriptor : 0
[ 6084.749] (--) NVIDIA(0): Audio Format : PCM
[ 6084.749] (--) NVIDIA(0): Maximum Channels : 2
[ 6084.749] (--) NVIDIA(0): Sample Rates : 32KHz, 44KHz, 48KHz
[ 6084.749] (--) NVIDIA(0): Sample Sizes : 16-bits
[ 6084.749] (--) NVIDIA(0): Standard Timings:
[ 6084.749] (--) NVIDIA(0): 640 x 480 @ 60 Hz
[ 6084.749] (--) NVIDIA(0): 800 x 600 @ 60 Hz
[ 6084.749] (--) NVIDIA(0): 1024 x 768 @ 60 Hz
[ 6084.749] (--) NVIDIA(0): 1280 x 1024 @ 60 Hz
[ 6084.749] (--) NVIDIA(0): Detailed Timings:
[ 6084.749] (--) NVIDIA(0): 3840 x 2160 @ 60 Hz
[ 6084.749] (--) NVIDIA(0): Pixel Clock : 594.00 MHz
[ 6084.749] (--) NVIDIA(0): HRes, HSyncStart : 3840, 4016
[ 6084.749] (--) NVIDIA(0): HSyncEnd, HTotal : 4104, 4400
[ 6084.749] (--) NVIDIA(0): VRes, VSyncStart : 2160, 2168
[ 6084.749] (--) NVIDIA(0): VSyncEnd, VTotal : 2178, 2250
[ 6084.749] (--) NVIDIA(0): H/V Polarity : +/+
[ 6084.749] (--) NVIDIA(0): Image Size : 698 mm x 392 mm
[ 6084.749] (--) NVIDIA(0): 1920 x 1080 @ 60 Hz
[ 6084.749] (--) NVIDIA(0): Pixel Clock : 148.50 MHz
[ 6084.749] (--) NVIDIA(0): HRes, HSyncStart : 1920, 2008
[ 6084.749] (--) NVIDIA(0): HSyncEnd, HTotal : 2052, 2200
[ 6084.749] (--) NVIDIA(0): VRes, VSyncStart : 1080, 1084
[ 6084.749] (--) NVIDIA(0): VSyncEnd, VTotal : 1089, 1125
[ 6084.749] (--) NVIDIA(0): Established Timings:
[ 6084.749] (--) NVIDIA(0): CEA-861B Timings:
[ 6084.749] (--) NVIDIA(0): Pixel Clock : 148.35 MHz
[ 6084.749] (--) NVIDIA(0): CEA Format : 16
[ 6084.749] (--) NVIDIA(0): Aspect Ratio : 16:9
[ 6084.749] (--) NVIDIA(0): Pixel Clock : 74.18 MHz
[ 6084.749] (--) NVIDIA(0): VSyncEnd, VTotal : 1094, 1124
[ 6084.749] (--) NVIDIA(0): Interlaced : yes
[ 6084.749] (--) NVIDIA(0): CEA Format : 5
[ 6084.749] (--) NVIDIA(0): 1920 x 1080 @ 24 Hz
[ 6084.749] (--) NVIDIA(0): Pixel Clock : 74.16 MHz
[ 6084.749] (--) NVIDIA(0): HRes, HSyncStart : 1920, 2558
[ 6084.749] (--) NVIDIA(0): HSyncEnd, HTotal : 2602, 2750
[ 6084.749] (--) NVIDIA(0): CEA Format : 32
[ 6084.749] (--) NVIDIA(0): 1920 x 1080 @ 30 Hz
[ 6084.749] (--) NVIDIA(0): CEA Format : 34
[ 6084.749] (--) NVIDIA(0): 1280 x 720 @ 60 Hz
[ 6084.749] (--) NVIDIA(0): HRes, HSyncStart : 1280, 1390
[ 6084.749] (--) NVIDIA(0): HSyncEnd, HTotal : 1430, 1650
[ 6084.749] (--) NVIDIA(0): VRes, VSyncStart : 720, 725
[ 6084.749] (--) NVIDIA(0): VSyncEnd, VTotal : 730, 750
[ 6084.749] (--) NVIDIA(0): CEA Format : 4
[ 6084.749] (--) NVIDIA(0): 720 x 480 @ 60 Hz
[ 6084.749] (--) NVIDIA(0): Pixel Clock : 27.00 MHz
[ 6084.749] (--) NVIDIA(0): HRes, HSyncStart : 720, 736
[ 6084.749] (--) NVIDIA(0): HSyncEnd, HTotal : 798, 858
[ 6084.749] (--) NVIDIA(0): VRes, VSyncStart : 480, 489
[ 6084.749] (--) NVIDIA(0): VSyncEnd, VTotal : 495, 525
[ 6084.749] (--) NVIDIA(0): H/V Polarity : -/-
[ 6084.749] (--) NVIDIA(0): CEA Format : 2
[ 6084.749] (--) NVIDIA(0): Aspect Ratio : 4:3
[ 6084.749] (--) NVIDIA(0): HRes, HSyncStart : 1440, 1478
[ 6084.749] (--) NVIDIA(0): HSyncEnd, HTotal : 1602, 1716
[ 6084.749] (--) NVIDIA(0): VRes, VSyncStart : 480, 488
[ 6084.749] (--) NVIDIA(0): VSyncEnd, VTotal : 494, 524
[ 6084.749] (--) NVIDIA(0): CEA Format : 7
[ 6084.749] (--) NVIDIA(0): CEA Format : 6
[ 6084.749] (--) NVIDIA(0): Pixel Clock : 593.41 MHz
[ 6084.749] (--) NVIDIA(0): CEA Format : 97
[ 6084.749] (--) NVIDIA(0): 3840 x 2160 @ 24 Hz
[ 6084.749] (--) NVIDIA(0): Pixel Clock : 296.75 MHz
[ 6084.749] (--) NVIDIA(0): HRes, HSyncStart : 3840, 5116
[ 6084.749] (--) NVIDIA(0): HSyncEnd, HTotal : 5204, 5500
[ 6084.750] (--) NVIDIA(0): VSyncEnd, VTotal : 2178, 2250
[ 6084.750] (--) NVIDIA(0): H/V Polarity : +/+
[ 6084.750] (--) NVIDIA(0): CEA Format : 93
[ 6084.750] (--) NVIDIA(0): Aspect Ratio : 16:9
[ 6084.750] (--) NVIDIA(0): 3840 x 2160 @ 30 Hz
[ 6084.750] (--) NVIDIA(0): Pixel Clock : 296.70 MHz
[ 6084.750] (--) NVIDIA(0): HRes, HSyncStart : 3840, 4016
[ 6084.750] (--) NVIDIA(0): HSyncEnd, HTotal : 4104, 4400
[ 6084.750] (--) NVIDIA(0): VRes, VSyncStart : 2160, 2168
[ 6084.750] (--) NVIDIA(0): CEA Format : 95
[ 6084.750] (--) NVIDIA(0): 4096 x 2160 @ 60 Hz
[ 6084.750] (--) NVIDIA(0): Pixel Clock : 593.41 MHz
[ 6084.750] (--) NVIDIA(0): HRes, HSyncStart : 4096, 4184
[ 6084.750] (--) NVIDIA(0): HSyncEnd, HTotal : 4272, 4400
[ 6084.750] (--) NVIDIA(0): CEA Format : 102
[ 6084.750] (--) NVIDIA(0): Image Size : 256 mm x 135 mm
[ 6084.750] (--) NVIDIA(0): 4096 x 2160 @ 24 Hz
[ 6084.750] (--) NVIDIA(0): Pixel Clock : 296.75 MHz
[ 6084.750] (--) NVIDIA(0): HRes, HSyncStart : 4096, 5116
[ 6084.750] (--) NVIDIA(0): HSyncEnd, HTotal : 5204, 5500
[ 6084.750] (--) NVIDIA(0): CEA Format : 98
[ 6084.750] (--) NVIDIA(0): 4096 x 2160 @ 30 Hz
[ 6084.750] (--) NVIDIA(0): CEA Format : 100
[ 6084.750] (--) NVIDIA(0): Extension Block Detailed Timings:
[ 6084.750] (--) NVIDIA(0): 1920 x 1080 @ 60 Hz
[ 6084.750] (--) NVIDIA(0): Pixel Clock : 74.25 MHz
[ 6084.750] (--) NVIDIA(0): HRes, HSyncStart : 1920, 2008
[ 6084.750] (--) NVIDIA(0): HSyncEnd, HTotal : 2052, 2200
[ 6084.750] (--) NVIDIA(0): VRes, VSyncStart : 1080, 1084
[ 6084.750] (--) NVIDIA(0): VSyncEnd, VTotal : 1094, 1124
[ 6084.750] (--) NVIDIA(0): Interlaced : yes
[ 6084.750] (--) NVIDIA(0): Image Size : 698 mm x 392 mm
[ 6084.750] (--) NVIDIA(0): 2560 x 1440 @ 60 Hz
[ 6084.750] (--) NVIDIA(0): Pixel Clock : 241.50 MHz
[ 6084.750] (--) NVIDIA(0): HRes, HSyncStart : 2560, 2608
[ 6084.750] (--) NVIDIA(0): HSyncEnd, HTotal : 2640, 2720
[ 6084.750] (--) NVIDIA(0): VRes, VSyncStart : 1440, 1443
[ 6084.750] (--) NVIDIA(0): VSyncEnd, VTotal : 1448, 1481
[ 6084.750] (--) NVIDIA(0): H/V Polarity : +/-
[ 6084.750] (--) NVIDIA(0): 1366 x 768 @ 60 Hz
[ 6084.750] (--) NVIDIA(0): Pixel Clock : 85.50 MHz
[ 6084.750] (--) NVIDIA(0): HRes, HSyncStart : 1366, 1436
[ 6084.750] (--) NVIDIA(0): HSyncEnd, HTotal : 1579, 1792
[ 6084.750] (--) NVIDIA(0): VRes, VSyncStart : 768, 771
[ 6084.750] (--) NVIDIA(0): VSyncEnd, VTotal : 774, 798
[ 6084.750] (--) NVIDIA(0): HDMI Extended Resolution Timings:
[ 6084.750] (--) NVIDIA(0): 3840 x 2160 @ 24 Hz
[ 6084.750] (--) NVIDIA(0): HRes, HSyncStart : 3840, 5116
[ 6084.750] (--) NVIDIA(0): Pixel Clock : 297.00 MHz
[ 6084.750] (--) NVIDIA(0): --- End of EDID for Panasonic-TV (HDMI-0) ---
[ 6084.750] (--) NVIDIA(0): Raw EDID bytes:
[ 6084.750] (--) NVIDIA(0): 00 ff ff ff ff ff ff 00 34 a9 96 a2 01 01 01 01
[ 6084.750] (--) NVIDIA(0): 00 18 01 03 80 80 48 78 0a da ff a3 58 4a a2 29
[ 6084.750] (--) NVIDIA(0): 17 49 4b 21 08 00 31 40 45 40 61 40 81 80 01 01
[ 6084.750] (--) NVIDIA(0): 01 01 01 01 01 01 08 e8 00 30 f2 70 5a 80 b0 58
[ 6084.750] (--) NVIDIA(0): 8a 00 ba 88 21 00 00 1e 02 3a 80 18 71 38 2d 40
[ 6084.750] (--) NVIDIA(0): 58 2c 45 00 ba 88 21 00 00 1e 00 00 00 fc 00 50
[ 6084.750] (--) NVIDIA(0): 61 6e 61 73 6f 6e 69 63 2d 54 56 0a 00 00 00 fd
[ 6084.750] (--) NVIDIA(0): 00 17 3d 0f 88 3c 00 0a 20 20 20 20 20 20 01 9f
[ 6084.750] (--) NVIDIA(0): 02 03 43 f0 4f 10 05 20 22 04 03 02 07 06 61 5d
[ 6084.750] (--) NVIDIA(0): 5f 66 62 64 23 09 07 01 77 03 0c 00 40 00 b8 3c
[ 6084.750] (--) NVIDIA(0): 2f c8 6a 01 03 04 81 41 00 16 06 08 00 56 58 00
[ 6084.750] (--) NVIDIA(0): 67 d8 5d c4 01 78 80 03 e2 00 4b e3 05 1f 01 e3
[ 6084.750] (--) NVIDIA(0): 0f 00 12 01 1d 80 18 71 1c 16 20 58 2c 25 00 ba
[ 6084.750] (--) NVIDIA(0): 88 21 00 00 9e 56 5e 00 a0 a0 a0 29 50 30 20 35
[ 6084.750] (--) NVIDIA(0): 00 ba 88 21 00 00 1a 66 21 56 aa 51 00 1e 30 46
[ 6084.750] (--) NVIDIA(0): 8f 33 00 ba 88 21 00 00 1e 00 00 00 00 00 00 62
