sundar2
September 28, 2023, 6:20am
1
Hi ,
When I try to directly connect the imx-728 camera with jetson agx xavier , it works properly. But now we have a custom chip inbetween which converts the csi2 (dphy) to base-t1. The connection is as follows , imx-728 camera <==> custom chip master dphy-Rx <==> base-t1 cable <==> custom chip slave dphy-tx <==> jetson agx xavier
In this setup it produces pinky purple video stream as shown below, anyone has any clue why is this happening? How can I rectify this issue?
I have the drivers loaded as suggested by leopard imaging.
@leopard-zwc
Try dump the raw image by v4l2-ctl to confirm the output source from custom slave chip.
sundar2
September 28, 2023, 5:31pm
4
v4l2-ctl --set-fmt-video=width=3856,height=2176,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100 --stream-to=/home/axonne/imx728.raw -d /dev/video0
I am using the above command which is taking too long.
I also do not know the command to convert it to .mp4 using a gstreamer pipeline.
Currently I am using,
gst-launch-1.0 nvarguscamerasrc sensor-mode=0 ! 'video/x-raw(memory:NVMM), width=3856, height=2176, format=(string)NV12, framerate=(fraction)29/1' ! nvvidconv flip-method=2 ! nv3dsink -e
sundar2:
You may capture just one frame instead of 100:
--stream-count=1
If you don’t have a viewer for RG10, you may have a look to : Stream Bayer Data with Gtsreamer - #8 by Honey_Patouceul
sundar2:
You may try:
gst-launch-1.0 nvarguscamerasrc sensor-mode=0 ! 'video/x-raw(memory:NVMM), width=3856, height=2176, format=(string)NV12, framerate=(fraction)29/1' ! nvvidconv flip-method=2 ! nvv4l2h264enc ! queue ! h264parse ! qtmux ! filesink location=test.mp4 -e
sundar2
September 28, 2023, 6:07pm
6
NVMEDIA: Need to set EMC bandwidth : 2776266
Im getting something like this, It is taking a while for the gst pipeline.
I’d advise to first try at V4L level, for one frame first, then for video at a suitable framerate for your sensor.
Only when these would be ok, you may try Argus and gstreamer.
sundar2
September 30, 2023, 8:36pm
8
Sure thank you. Will try and let you know
system
Closed
October 25, 2023, 7:14am
10
