Libargus Performance
We observe a high CPU load and multiple processes spawned by libargus for a single cam (12MP Color@20fps), basically just a free running image pipeline:
█████████████████████████████████ 5.45 % CaptureSchedule (6453) 0 [20]
███████████████████ 3.12 % SCF Execution (6440) 0 [20]
███████████████████ 3.10 % SCF Execution (6436) 0 [20]
I saw similar questions around, which not really got answered though:
Questions:
(1) What are these doing? (I assume some CPU side processing for the ISP)
(2) Why is this that running with ~10% CPU, when there is a hardware ISP available?
(3) Is there a way to diagnose this any deeper? (Maybe this could be reduced by options on the argus pipeline)
Best,
Axel
hello zschutschke,
it’s camera application and EGL streams consume CPU resources, EGL is used by Argus APIs for buffer/stream management. mostly CPU usage was taken by argus_camera application due to buffer transmit. however, camera pipeline still need CPU to run lots of algorithms like AE, AWB, ToneMap…etc.
you may give it a try to disable camera preview frames, fetch the streaming by reporting frame-rate only.
this should result lower CPU usage since display rendering has disabled.
for example,
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=I420' ! fpsdisplaysink text-overlay=0 video-sink=fakesink sync=0 -v
Hi Jerry, thank you for your quick reply!
So basically, the auto-features are implemented as soft-ISP? I see that there will always be some overhead when it comes to buffer management and frame hand-over (on our side as well, the data needs to go somewhere obviously).
Is there a list of ISP features and whether they are solved in HW or in SW?
Best,
Axel
hello zschutschke,
may I have your expectation of CPU usage?
FYI, we’ve evaluation of the CPU usage by running 6-cam reference board on AGX Xavier, all of them were running at 1920x1440@30-fps.
the result shows the linear increase with multiple image sensors, which is 2% per camera.
I don’t have a fixed expectation. Just curious, why there is a significant CPU load to begin with, when we are talking about a system with an advertised hardware ISP. As I learn from your previous answer, parts of the ISP are implemented in software.
Best,
Axel
sorry, there’s no public documentation to list ISP features.
Thank you Jerry! I think this coarsely answers the question what the processes are doing.
One final question: we see two SCF Execution processes running for a single camera stream. Is this the expected behavior, or this an error on our side?
Best,
Axel
hello zschutschke,
please also share the complete steps, which application you’re used to enable camera stream.
what’s the app you’re used to monitor the CPU usage, BTW, had you try $ ps aux for checking its CPU usage also?
