We have been observing very high CPU usage for just simply streaming two CSI2 cameras on the Jetson NX. I am kicking off this thread for discussing this issue on the Jetson NX platform at the request of @JerryChang.
Background
This forum has previously discussed unexplainable and concerningly high CPU loads when using the Nvidia Argus CSI2 Deepstream plugin ( nvarguscamerasrc
). Others have experienced this with the Jetson Nano as well.
This reply aims to provide a concrete example that anyone with a Jetson device (we’re testing on Jetson NX ) can run to see the high CPU usage for themselves.
Goal
This post is seeking to understand why the overhead is so high, if it can be reduced, and if so how to reduce it. We additionally would like for everyone to be able to quickly run a couple of the same expirements we have and to observe the overhead for themselves.
Observing the Overhead
For these expirements we will use up to two IMX219-160 cameras, connected to the Jetson NX developer kit’s CSI2 ribbon cable connectors. You should configure the resolution and framerate in the expirements to values supported by your own cameras.
For a single CSI2 camera, you can run the following:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)3280, height=(int)2464, format=(string)NV12, framerate=(fraction)21/1' ! nvvidconv ! queue ! fakesink
To terminate this pipeline you can use CTRL-C
in your terminal at any time to send SIGINT
While this is running open a new terminal and observe the CPU usage of /usr/sbin/nvargus-daemon
. One way to do this is to run htop
(installed via sudo apt install htop
) and click on the CPU
column to filter processes by order of CPU load. The nvargus-daemon
process should appear at or near the top with around 18% CPU load.
An alternative means of viewing this is to run:
top -p `pgrep "nvargus"`
For two cameras you can run:
gst-launch-1.0 nvarguscamerasrc sensor-id=1 ! 'video/x-raw(memory:NVMM), width=(int)3280, height=(int)2464, format=(string)NV12, framerate=(fraction)21/1' ! nvvidconv ! queue ! fakesink nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)3280, height=(int)2464, format=(string)NV12, framerate=(fraction)21/1' ! nvvidconv ! queue ! fakesink
Observations
For the MODE_10W_4CORE
with the clocks like so:
Online CPUs: 0-3
cpu0: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=1 c6=1
cpu1: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=1 c6=1
cpu2: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=1 c6=1
cpu3: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=1 c6=1
cpu4: Online=0 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=1 c6=1
cpu5: Online=0 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=1 c6=1
GPU MinFreq=114750000 MaxFreq=803250000 CurrentFreq=114750000
EMC MinFreq=204000000 MaxFreq=1600000000 CurrentFreq=1600000000 FreqOverride=0
Fan: PWM=130
NV Power Mode: MODE_10W_4CORE
We observed ~18% CPU utilization for a single camera and up to ~37% with two cameras.
Then we re-ran with the max clock frequency (using sudo jetson_clocks
) and got:
SOC family:tegra194 Machine:NVIDIA Jetson Xavier NX Developer Kit
Online CPUs: 0-3
cpu0: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu1: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu2: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu3: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu4: Online=0 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu5: Online=0 Governor=schedutil MinFreq=1190400 MaxFreq=1190400 CurrentFreq=1190400 IdleStates: C1=0 c6=0
GPU MinFreq=803250000 MaxFreq=803250000 CurrentFreq=803250000
EMC MinFreq=204000000 MaxFreq=1600000000 CurrentFreq=1600000000 FreqOverride=1
Fan: PWM=130
We saw similar values with the other clock frequency settings.
