vsw
1
Hardware TX2 l4t 32.2.1, imx577.
My code:
Argus::BayerTuple< float > wb{ iAutoControlSettings->getWbGains() };
std::cout << "getWbGains: " << wb[ 0 ] << ", " << wb[ 1 ] << ", " << wb[ 2 ] << ", " << wb[ 3 ] << std::endl;
wb[ 0 ] = 0.f;
wb[ 1 ] = 0.f;
wb[ 2 ] = 0.f;
wb[ 3 ] = 0.f;
iAutoControlSettings->setWbGains( wb );
wb = { iAutoControlSettings->getWbGains() };
Output:
getWbGains: 1, 1, 1, 1
getWbGains: 0, 0, 0, 0
But the picture has no effect.
Other settings work.
Please help.
Best regards, Viktor.
AWB may not direct observation. Have you try any others value?
vsw
4
Have tried:
getWbGains: 2, 0.5, 2, 0.5
But nothing.
Not sure, but you might have to set awblock to true in order to prevent auto WB adjustments.
vsw
6
Ae and awb locked cause i use manual settings.
If awb mode is manual (or off) and you’ve also disabled auto-exposure, set fixed gain and digital gain, I cannot help further !
vsw
8
Thank you. I wrote to LI. May be it is driver issue.
Will reply here.
vsw
10
Yes.
I should set awb to false, ae to true and awb_mode to manual.
Then RGGB gains works.
Hi
what is the min max for wbGains could be set. is 0.0 to 1.0 or 1.0 to 255.0 ?
I could not find min max range in LibArgus API Document… please help.
It’s 4 channel array of 0 - 255 for rggb channel value.
Have a reference to the tegra_multimedia_api sample code.
…/samples/userAutoWhiteBalance/main.cpp
vsw
13
My case 2.3, 1, 1, 1.5
It is not normalized 0-1 values.
