Hello ,
I’m trying to install libnvidia-compute-util-550 package on AGX Orin (JP6.0 m,Ubuntu 22.04). But it fails because libcuda.so which is provided by nvidia-l4t-cuda (36.2 ) could not be overwritten. I need both the packages for our project. How can I solve dependency issue?
You will need a package for the Jetson platform.
The package you try to install is for the x86 environment?
Could you share where you downloaded the package?
Hi ,
The Package I’m trying to install is for ARM platform.
I downloaded the packages from UBUNTU/NVIDIA repo through synaptic
Would mind sharing the link so we can check it further?
There is no link to download. I installed it through Ubuntu synaptic package manager.
You can also install it by issuing following command
“sudo apt-get install libnvidia-compute-550”
which is results in following error
“trying to overwrite ‘/usr/lib/aarch64-linux-gnu/libcuda.so’ , which is also in package nvidia-l4t-cuda 36.2.0-202312182148”
Just want to double-confirm the info.
Do you run this command on the Jetson device?
I’m running the command on AGX Orin 64GB updated to latest Jetpacks 6.0
The problem raised when I’m installing drivers for “NVIDIA® ConnectX-6 Lx Dual Port 10/25GbE SFP28 Adapter, PCIe Low Profile” from the following link “Ethernet drivers and acceleration software | NVIDIA | NVIDIA Developer” .
“libnvidia-compute-550” package is required for the drivers to install which is conflicting with “nvidia-l4t-cuda”
The libnvidia-compute-550 sounds more like a dGPU driver and is not able to work on Jetson.
iGPU driver comes with OS so it’s installed after reflashing with JetPack 6.
Please verify this via running nvidia-smi.
nvidia-smi is not showing any information apart from NVIDIA-SMI:540.2.0 , CUDA version : 12.2 versions.
Due to iGPU and shared memory environment, some info of nvidia-smi is not available.
But you should be able to find the GPU and CUDA info like below:
$ nvidia-smi
Wed Jul 17 02:57:45 2024
| NVIDIA-SMI 540.3.0 Driver Version: N/A CUDA Version: 12.5 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Orin (nvgpu) N/A | N/A N/A | N/A |
In our case, driver (540.3.0) and CUDA (12.5) are well-installed.
