Hii
I did this command :
sudo apt-get --purge remove “cublas” “cuda*” “nsight*” “nvidia”
After this using jtop , I check the driver i got ::
Cuda , l4t and jetpack all is missing
After rebooting the fan working a while and stop , can’t reach it over ip
Is there any possible to work again?
I use jetson agx orin
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Thank u Mr. Tom
I which to get the reply ASAP!!
Hi ahmadsondos103,
It may be expected result since they have dependancy.
Could you try running the following command to install Jetpack?
$ sudo apt-get install nvidia-jetpack
Or you can re-flash the board to check if it could help.
Yes it’s jetson agx orin
The jetson isnt openinig to try the command that u gave and fan is stopping after a while.
Please share the full serial console log for further check.
Have you also tried to re-flash the board?
Thanks, it was solved by flashing.
