I’m running CUDA 1.0 x86-64 on a fresh install of Ubuntu 7.04.
The program runs fine, as it did under 0.8, but it segfaults when the application terminates. Here’s what I’m getting from GDB:
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 47532137146368 (LWP 15029)]
0x00002b3aee3a6702 in ?? () from /usr/local/cuda/lib/libcudart.so
(gdb) bt
#0 0x00002b3aee3a6702 in ?? () from /usr/local/cuda/lib/libcudart.so
#1 0x00002b3af0163c65 in __tlsHookDeleteIndex () from /usr/local/cuda/lib/libtlshook.so
#2 0x00002b3aee3a4df2 in ?? () from /usr/local/cuda/lib/libcudart.so
#3 0x00007fffbcf585d0 in ?? ()
#4 0x00002b3aee3c5071 in ?? () from /usr/local/cuda/lib/libcudart.so
#5 0x0000000000000000 in ?? ()
Just to check, I added a “press enter to quit” thing at the very end of the program, after all the cleanup is done. It’s definitely happening when the main loop terminates, and not a delayed reaction from freeing the resources.
