After upgrading to CUDA 10.1 Update 1, I’m receiving the following error.
libcupti.so not found
I also received this error with CUDA 10.1 but was able to fix it with export below:
export LD_LIBRARY_PATH=/usr/local/cuda/extras/CUPTI/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
Even though libcupti.so is in the same location after the update, the error persists.
I’m using PGI_ACC_TIME=1 to profile OpenACC code.
The code can be found at https://github.com/mnicely/computeWorks_examples/tree/master/computeWorks_mm.
Add you can see if the following out the device code is not begin profiled.
Accelerator Kernel Timing data
_Z7openACCifPKfS0_fPfRKi NVIDIA devicenum=0
time(us): 43,743
163: compute region reached 1000 times
169: kernel launched 1000 times
grid: [1x128] block: [128]
elapsed time(us): total=71,907 max=164 min=20 avg=71
163: data region reached 2000 times
163: data copyin transfers: 2000
device time(us): total=26,742 max=19 min=13 avg=13
178: data copyout transfers: 1000
device time(us): total=17,001 max=22 min=13 avg=17
Matt
