libopencv_3.3.1_t186_arm64 GPU acceleration is available or is it deprecated ?
Please provide installation instructions
If you are asking the opencv3.3.1 installed by Jetpack3.2, the answer is no. GPU acceleration is disabled.
We provide a quick tool to install opencv, but it is openCV3.4. Is it okay?
https://github.com/AastaNV/JEP/blob/master/script/install_opencv3.4.0.sh
Thanks. it works now
I have installed the jetpack 3.2 but I am facing some problems during the post installation, is it possible to install the libraries such as opencv , tensorRT etc separately or do I have to use only jetpack to do the installation on the Jetson TX2 ?
You can find libraries located at ‘[JetPack]/jetpack_download’.
Manually installation should work.
You can give it a try.
