I wanted to use the lift environment from isaac lab to change it to my environment, but when I tried to change the target location, I found that it could not be changed, even if I set it to below code seems to be useless
object_pose = mdp.UniformPoseCommandCfg(
asset_name=“robot”,
body_name=MISSING,
resampling_time_range=(4.0, 4.0),
debug_vis=True,
ranges=mdp.UniformPoseCommandCfg.Ranges(
pos_x=(0, 0),
pos_y=(0, 0),
pos_z=(0, 0),
roll=(0.0, 0.0),
pitch=(0, 0), # depends on end-effector axis
yaw=(0, 0),
Thank you for your interest in Isaac Lab. I hope you have found your way to its GitHub repository. To ensure efficient support and collaboration, please submit your topic to Isaac Lab’s issues or discussions following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
