I am trying to convert the ViperX 300 6DOF arm from the Mujoco menagerie to a USD Articulation object to use for a manipulation task in IsaacLab.
I would expect the arm to stay put under gravity, but the arm falls as soon as gravity is applied to the scene. This occurs regardless of the joint stiffness and damping values (even when I try with high stiffness, for instance). If I set joint positions using set_joint_position_target, the arm will still fall. This is a video of the arm falling when placing it on a ground plane, even with joint positions applied:
Steps to Reproduce
Clone the Mujoco menagerie, and run the convert_mjcf script with
./isaaclab.sh -p source/standalone/tools/convert_mjcf.py \
~/Workspace/mujoco_menagerie/trossen_vx300s/vx300s.xml \
source/extensions/omni.isaac.lab_assets/data/Robots/VX300s/vx300s.usd \
--import-sites \
--make-instanceable \
--fix-base
I was following this tutorial from the IsaacLab documentation.
The arm falls when pressing play (as shown in the above video), even when I set the stiffness to something like 100000.0 and damping to something like 1000.0.
As a workaround, I tried disabling gravity for the arm like so: VIPER_HIGH_PD_CFG.spawn.rigid_props.disable_gravity = True.
However, this causes the robot to stay static when running the example standalone/tutorials/05_controllers/run_diff_ik.py script with my VIPER_HIGH_PD_CFG robot. The robot goes to the initial pose, but it does not move after that. I would expect the end effector to try to reach the target pose. This is what it looks like:
In the run_diff_ik.py file, I replaced the Franka robot with
robot_entity_cfg = SceneEntityCfg("robot", joint_names=["waist", "shoulder",
"elbow", "forearm_roll", "wrist_angle", "wrist_rotate",
"left_finger", "right_finger"], body_names=["gripper_prop_link"])
In comparison, this is what the Franka arm looks like when running that run_diff_ik.py script (expected behavior):
Questions
- Does anyone know why the converted articulated USD is falling under gravity despite the stiffness and damping being set for the joints?
- Additionally, if I set
disable_gravityto True, why does the robot only go to the initial requested pose, but not move to the commanded joints?
These two cases (the robot falling under gravity and the robot not moving at all when disable_gravity=True) seems to suggest that the robot is unable to be commanded at all.
Additional context
The reason why I am not using the URDF convertor (which is probably more supported) is because the ViperX 300 arm URDF is in the XACRO format, and I haven’t been able to convert that to a URDF.
For reference, this is my
viper.pyconfiguration file:import omni.isaac.lab.sim as sim_utils from omni.isaac.lab.actuators import ImplicitActuatorCfg from omni.isaac.lab.assets.articulation import ArticulationCfg ## # Configuration ## VIPER_CFG = ArticulationCfg( spawn=sim_utils.UsdFileCfg( usd_path="/home/maggiewang/Workspace/IsaacLab/source/extensions/omni.isaac.lab_assets/data/Robots/VX300s/vx300s_again.usd", activate_contact_sensors=False, rigid_props=sim_utils.RigidBodyPropertiesCfg( disable_gravity=False, max_depenetration_velocity=5.0, ), articulation_props=sim_utils.ArticulationRootPropertiesCfg( enabled_self_collisions=True, solver_position_iteration_count=8, solver_velocity_iteration_count=0 ), collision_props=sim_utils.CollisionPropertiesCfg(contact_offset=0.005, rest_offset=0.0), ), init_state=ArticulationCfg.InitialStateCfg( joint_pos={ "waist": 0.0, "shoulder": -0.96, "elbow": 1.16, "forearm_roll": 0.0, "wrist_angle": -0.3, "wrist_rotate": 0.0, "left_finger": 0.024, "right_finger": -0.024, }, ), actuators={ "waist": ImplicitActuatorCfg( joint_names_expr=["waist"], effort_limit=35.0, velocity_limit=2.286, # NOTE this actually doesn't set anything, need to set it in usd itself stiffness=25.0, damping=2.86, ), "shoulder": ImplicitActuatorCfg( joint_names_expr=["shoulder"], effort_limit=57.0, velocity_limit=2.286, stiffness=76.0, damping=6.25, ), "elbow": ImplicitActuatorCfg( joint_names_expr=["elbow"], effort_limit=25.0, velocity_limit=2.286, stiffness=106.0, damping=8.15, ), "forearm_roll": ImplicitActuatorCfg( joint_names_expr=["forearm_roll"], effort_limit=10.0, velocity_limit=2.286, stiffness=35.0, damping=3.07, ), "wrist_angle": ImplicitActuatorCfg( joint_names_expr=["wrist_angle"], effort_limit=35.0, velocity_limit=2.286, stiffness=8.0, damping=1.18, ), "wrist_rotate": ImplicitActuatorCfg( joint_names_expr=["wrist_rotate"], effort_limit=35.0, velocity_limit=2.286, stiffness=7.0, damping=7, ), "gripper": ImplicitActuatorCfg( joint_names_expr=["left_finger", "right_finger"], effort_limit=35.0, velocity_limit=2.286, stiffness=300.0, damping=1000.0, ), }, soft_joint_pos_limit_factor=1.0, ) """Configuration of Viper robot.""" VIPER_HIGH_PD_CFG = VIPER_CFG.copy() VIPER_HIGH_PD_CFG.spawn.rigid_props.disable_gravity = True VIPER_HIGH_PD_CFG.actuators["waist"].stiffness = 400.0 VIPER_HIGH_PD_CFG.actuators["waist"].damping = 80.0 VIPER_HIGH_PD_CFG.actuators["shoulder"].stiffness = 400.0 VIPER_HIGH_PD_CFG.actuators["shoulder"].damping = 80.0 VIPER_HIGH_PD_CFG.actuators["elbow"].stiffness = 400.0 VIPER_HIGH_PD_CFG.actuators["elbow"].damping = 80.0 -
This is my
run_diff_ik.pyfile:# Copyright (c) 2022-2024, The Isaac Lab Project Developers. # All rights reserved. # # SPDX-License-Identifier: BSD-3-Clause """ This script demonstrates how to use the differential inverse kinematics controller with the simulator. The differential IK controller can be configured in different modes. It uses the Jacobians computed by PhysX. This helps perform parallelized computation of the inverse kinematics. .. code-block:: bash # Usage ./isaaclab.sh -p source/standalone/tutorials/05_controllers/ik_control.py """ """Launch Isaac Sim Simulator first.""" import argparse from omni.isaac.lab.app import AppLauncher # add argparse arguments parser = argparse.ArgumentParser(description="Tutorial on using the differential IK controller.") parser.add_argument("--robot", type=str, default="franka_panda", help="Name of the robot.") parser.add_argument("--num_envs", type=int, default=128, help="Number of environments to spawn.") # append AppLauncher cli args AppLauncher.add_app_launcher_args(parser) # parse the arguments args_cli = parser.parse_args() # launch omniverse app app_launcher = AppLauncher(args_cli) simulation_app = app_launcher.app """Rest everything follows.""" import torch import omni.isaac.lab.sim as sim_utils from omni.isaac.lab.assets import AssetBaseCfg from omni.isaac.lab.controllers import DifferentialIKController, DifferentialIKControllerCfg from omni.isaac.lab.managers import SceneEntityCfg from omni.isaac.lab.markers import VisualizationMarkers from omni.isaac.lab.markers.config import FRAME_MARKER_CFG from omni.isaac.lab.scene import InteractiveScene, InteractiveSceneCfg from omni.isaac.lab.utils import configclass from omni.isaac.lab.utils.assets import ISAAC_NUCLEUS_DIR from omni.isaac.lab.utils.math import subtract_frame_transforms ## # Pre-defined configs ## from omni.isaac.lab_assets import FRANKA_PANDA_HIGH_PD_CFG, VIPER_HIGH_PD_CFG, UR10_CFG # isort:skip @configclass class TableTopSceneCfg(InteractiveSceneCfg): """Configuration for a cart-pole scene.""" # ground plane ground = AssetBaseCfg( prim_path="/World/defaultGroundPlane", spawn=sim_utils.GroundPlaneCfg(), init_state=AssetBaseCfg.InitialStateCfg(pos=(0.0, 0.0, -1.05)), ) # lights dome_light = AssetBaseCfg( prim_path="/World/Light", spawn=sim_utils.DomeLightCfg(intensity=3000.0, color=(0.75, 0.75, 0.75)) ) # mount table = AssetBaseCfg( prim_path="{ENV_REGEX_NS}/Table", spawn=sim_utils.UsdFileCfg( usd_path=f"{ISAAC_NUCLEUS_DIR}/Props/Mounts/Stand/stand_instanceable.usd", scale=(2.0, 2.0, 2.0) ), ) # articulation if args_cli.robot == "franka_panda": robot = VIPER_HIGH_PD_CFG.replace(prim_path="{ENV_REGEX_NS}/Robot") elif args_cli.robot == "ur10": robot = UR10_CFG.replace(prim_path="{ENV_REGEX_NS}/Robot") else: raise ValueError(f"Robot {args_cli.robot} is not supported. Valid: franka_panda, ur10") def run_simulator(sim: sim_utils.SimulationContext, scene: InteractiveScene): """Runs the simulation loop.""" # Extract scene entities # note: we only do this here for readability. robot = scene["robot"] # Create controller diff_ik_cfg = DifferentialIKControllerCfg(command_type="pose", use_relative_mode=False, ik_method="dls") diff_ik_controller = DifferentialIKController(diff_ik_cfg, num_envs=scene.num_envs, device=sim.device) # Markers frame_marker_cfg = FRAME_MARKER_CFG.copy() frame_marker_cfg.markers["frame"].scale = (0.1, 0.1, 0.1) ee_marker = VisualizationMarkers(frame_marker_cfg.replace(prim_path="/Visuals/ee_current")) goal_marker = VisualizationMarkers(frame_marker_cfg.replace(prim_path="/Visuals/ee_goal")) # Define goals for the arm ee_goals = [ [0.5, 0.5, 0.7, 0.707, 0, 0.707, 0], [0.5, -0.4, 0.6, 0.707, 0.707, 0.0, 0.0], [0.5, 0, 0.5, 0.0, 1.0, 0.0, 0.0], ] ee_goals = torch.tensor(ee_goals, device=sim.device) # Track the given command current_goal_idx = 0 # Create buffers to store actions ik_commands = torch.zeros(scene.num_envs, diff_ik_controller.action_dim, device=robot.device) ik_commands[:] = ee_goals[current_goal_idx] # Specify robot-specific parameters if args_cli.robot == "franka_panda": # robot_entity_cfg = SceneEntityCfg("robot", joint_names=["panda_joint.*"], body_names=["panda_hand"]) robot_entity_cfg = SceneEntityCfg("robot", joint_names=["waist", "shoulder", "elbow", "forearm_roll", "wrist_angle", "wrist_rotate", "left_finger", "right_finger"], body_names=["gripper_prop_link"]) elif args_cli.robot == "ur10": robot_entity_cfg = SceneEntityCfg("robot", joint_names=[".*"], body_names=["ee_link"]) else: raise ValueError(f"Robot {args_cli.robot} is not supported. Valid: franka_panda, ur10") # Resolving the scene entities robot_entity_cfg.resolve(scene) # Obtain the frame index of the end-effector # For a fixed base robot, the frame index is one less than the body index. This is because # the root body is not included in the returned Jacobians. if robot.is_fixed_base: ee_jacobi_idx = robot_entity_cfg.body_ids[0] - 1 else: ee_jacobi_idx = robot_entity_cfg.body_ids[0] # Define simulation stepping sim_dt = sim.get_physics_dt() count = 0 # Simulation loop while simulation_app.is_running(): # reset if count % 150 == 0: # reset time count = 0 # reset joint state joint_pos = robot.data.default_joint_pos.clone() joint_vel = robot.data.default_joint_vel.clone() robot.write_joint_state_to_sim(joint_pos, joint_vel) robot.reset() # reset actions ik_commands[:] = ee_goals[current_goal_idx] joint_pos_des = joint_pos[:, robot_entity_cfg.joint_ids].clone() # reset controller diff_ik_controller.reset() diff_ik_controller.set_command(ik_commands) # change goal current_goal_idx = (current_goal_idx + 1) % len(ee_goals) else: # obtain quantities from simulation jacobian = robot.root_physx_view.get_jacobians()[:, ee_jacobi_idx, :, robot_entity_cfg.joint_ids] ee_pose_w = robot.data.body_state_w[:, robot_entity_cfg.body_ids[0], 0:7] root_pose_w = robot.data.root_state_w[:, 0:7] joint_pos = robot.data.joint_pos[:, robot_entity_cfg.joint_ids] # compute frame in root frame ee_pos_b, ee_quat_b = subtract_frame_transforms( root_pose_w[:, 0:3], root_pose_w[:, 3:7], ee_pose_w[:, 0:3], ee_pose_w[:, 3:7] ) # compute the joint commands joint_pos_des = diff_ik_controller.compute(ee_pos_b, ee_quat_b, jacobian, joint_pos) # apply actions robot.set_joint_position_target(joint_pos_des, joint_ids=robot_entity_cfg.joint_ids) scene.write_data_to_sim() # perform step sim.step() # update sim-time count += 1 # update buffers scene.update(sim_dt) # obtain quantities from simulation ee_pose_w = robot.data.body_state_w[:, robot_entity_cfg.body_ids[0], 0:7] # update marker positions ee_marker.visualize(ee_pose_w[:, 0:3], ee_pose_w[:, 3:7]) goal_marker.visualize(ik_commands[:, 0:3] + scene.env_origins, ik_commands[:, 3:7]) def main(): """Main function.""" # Load kit helper sim_cfg = sim_utils.SimulationCfg(dt=0.01, device=args_cli.device) sim = sim_utils.SimulationContext(sim_cfg) # Set main camera sim.set_camera_view([2.5, 2.5, 2.5], [0.0, 0.0, 0.0]) # Design scene scene_cfg = TableTopSceneCfg(num_envs=args_cli.num_envs, env_spacing=2.0) scene = InteractiveScene(scene_cfg) # Play the simulator sim.reset() # Now we are ready! print("[INFO]: Setup complete...") # Run the simulator run_simulator(sim, scene) if __name__ == "__main__": # run the main function main() # close sim app simulation_app.close()
