I’ve installed the Cuda SDK and Cuda driver for linux v. 2.3. I’m also running Fedora 11 which is perhaps not advisable but out of my hands. I get the following error when I try to make from the CUDA_SDK/C directory:
make[1]: Entering directory /home/lamberh/NVIDIA_GPU_Computing_SDK/C/src/threadFenceReduction' threadFenceReduction.cu:52:26: error: cutil_inline.h: No such file or directory make[1]: *** [obj/release/threadFenceReduction.cu_sm_11.o] Error 255 make[1]: Leaving directory /home/lamberh/NVIDIA_GPU_Computing_SDK/C/src/threadFenceReduction’
make: *** [src/threadFenceReduction/Makefile.ph_build] Error 2
I assume the examples are looking for the libcutil.so etc. files. All I seem to have is libcutil.a files in the lib directory. Should the make file be generating and linking to those .so files or am I way off the mark?
Obviously, your problem is not about gcc version yet. It is about whether the file cutil_inline.h exists, or its path be put into include path search. Please check this. It is located at:
On my machine, building threadFenceReduction after export verbose=1
It was a problem with the makefile, they were pointing all in the wrong direction. I’ve compiled all the software examples. ./deviceQueryDrv works fine and generates the following output:
There are 2 devices supporting CUDA
Device 0: “Tesla C1060”
CUDA Driver Version: 2.20
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 3
Total amount of global memory: 4294705152 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.30 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: No
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Device 1: “Quadro NVS 295”
Total amount of global memory: 267714560 bytes
Number of multiprocessors: 1
Number of cores: 8
Total number of registers available per block: 8192
Warp size: 32
Concurrent copy and execution: No
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: No
Test PASSED
However deviceQuery says there is no device supporting cuda and bandWidthTest gives a segmentation fault.
