Hello People,
My goal is to have the display resolution of 804x1286 and to have the display rotated ninety degrees (landscape) making it 1286 x 804.
When I boot Ubuntu I only see one display resolution available. The resolution is 1200x1900 and it is in portrait mode.
I have attempted to add resolutions to xorg.conf manually and tried to use xrandr to add resolutions. These attempts appear to have failed.
I have been able to use xrandr to scale the resolution. Combined with the option to rotate the display using the display options applet, I can get what I want. However, this does not apply to other window managers (xubuntu or lubuntu, for example) and has to be performed upon every reboot.
When I do this, the cursor appears flipped and reversed, i.e. moving down and to the right moves the cursor up and to the left … kinda.
How can I add display resolutions so that I can select them from the display applet and are available to xubuntu, lubuntu, etc)?
Thank you,
=thoth=
Some Info:
gtf 1286 804 60
# 1288x804 @ 60.00 Hz (GTF) hsync: 49.92 kHz; pclk: 84.26 MHz
Modeline "1288x804_60.00" 84.26 1288 1352 1488 1688 804 805 808 832 -HSync +Vsync
xrandr
Screen 0: minimum 8 x 8, current 1200 x 1920, maximum 16384 x 16384
DSI-0 connected primary 1200x1920+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1200x1920 60.0*+
HDMI-0 disconnected (normal left inverted right x axis y axis)
xrandr --q1
SZ: Pixels Physical Refresh
*0 1200 x 1920 ( 406mm x 650mm ) *50
1 1024 x 768 ( 346mm x 260mm ) 51
2 800 x 600 ( 270mm x 203mm ) 52
3 640 x 480 ( 216mm x 162mm ) 53
4 1200 x 675 ( 406mm x 228mm ) 54
Current rotation - normal
Current reflection - none
Rotations possible - normal left inverted right
Reflections possible - X Axis Y Axis
Does not exist:
/etc/X11/xorg.conf.d/10-monitor.conf
and is instead located at
/usr/share/X11/xorg.conf.d/10-monitor.conf
/usr/share/X11/xorg.conf.d/10-monitor.conf (one attempt to add a mode)
Section "Monitor"
Identifier "Monitor0"
Modeline "1280x800_60.00" 83.46 1280 1344 1480 1680 800 801 804 828 -HSync +Vsync
EndSection
Section "Screen"
Identifier "Screen0"
Device "DSI-0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1280x800_60.00"
EndSubSection
/etc/X11/xorg.conf
# Copyright (c) 2011-2013 NVIDIA CORPORATION. All Rights Reserved.
# This is the minimal configuration necessary to use the Tegra driver.
# Please refer to the xorg.conf man page for more configuration
# options provided by the X server, including display-related options
# provided by RandR 1.2 and higher.
# Disable extensions not useful on Tegra.
Section "Module"
Disable "dri"
SubSection "extmod"
Option "omit xfree86-dga"
EndSubSection
EndSection
/etc/X11/xorg.conf.jetson-tk1
# Copyright (c) 2011-2014 NVIDIA CORPORATION. All Rights Reserved.
Section "Module"
Disable "dri"
SubSection "extmod"
EndSubSection
EndSection
Section "Device"
Identifier "Tegra0"
Driver "nvidia"
EndSection
Section "Monitor"
Identifier "DSI-0"
Option "Ignore"
EndSection
