Hello All,
What are the steps to build the Linux Kernel in Native mode, i.e. Xavier Nx board itself.
-Thanks.
Hello All,
-Thanks.
This assumes 6 cores (thus “-j 6”). Also assumes “${HOME}” is where your output will go, and that the source itself is located at “/usr/src/sources/kernel/kernel-4.9” (adjust for your situation). Something like this:
# --- Setting Up: -------------------------------------------------------
# DO NOT BUILD AS ROOT/SUDO!!! You might need to install source code as root/sudo.
mkdir -p "${HOME}/build/kernel"
mkdir -p "${HOME}/build/modules"
mkdir -p "${HOME}/build/firmware"
export TOP="/usr/src/sources/kernel/kernel-4.9"
export TEGRA_KERNEL_OUT="${HOME}/build/kernel"
export TEGRA_MODULES_OUT="${HOME}/build/modules"
export TEGRA_FIRMWARE_OUT="${HOME}/build/firmware"
export TEGRA_BUILD="${HOME}/build"
# --- Notes: ------------------------------------------------------------
# It is assumed kernel source is at "/usr/src/sources/kernel/kernel-4.9".
# Check if you have 6 CPU cores, e.g., via "htop".
# If you are missing cores, then experiment with "sudo nvpmodel -m 0, -m 1, and -m 2".
# Perhaps use "htop" to see core counts.
# Using "-j 6" in hints below because of assumption of 6 cores.
# Compile commands start in $TOP, thus:
cd $TOP
# Do not forget to provide a starting configuration. Probably copy of "/proc/config.gz",
# to $TEGRA_KERNEL_OUT, but also perhaps via:
make O=$TEGRA_KERNEL_OUT nconfig
# If building the kernel Image:
make -j 6 O=$TEGRA_KERNEL_OUT Image
# If you did not build Image, but are building modules:
make -j 6 O=$TEGRA_KERNEL_OUT modules_prepare
# To build modules:
# To build device tree content:
make -j 6 O=$TEGRA_KERNEL_OUT dtbs
# To put modules in "$TEGRA_MODULES_OUT":
make -j 6 O=$TEGRA_KERNEL_OUT INSTALL_MOD_PATH=$TEGRA_MODULES_OUT
# To put firmware and device trees in "$TEGRA_FIRMWARE_OUT":
make -j 6 O=$TEGRA_KERNEL_OUT INSTALL_FW_PATH=$TEGRA_FIRMWARE_OUT
Note that:
modules_prepare target is only needed if you don’t build the Image first.CONFIG_LOCALVERSION, and thus the same “uname -r”, then you might not need to build modules. Or perhaps you would build just a single module for whatever you’ve added.Image target at least once even if you are not installing a new base kernel. Think of it as an “acid test” for configuration./boot/extlinux/extlinux.conf” which you’ve picked via serial console at boot time.This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
