LInux kernel: invoke callback function in user space from the kernel space
I am writing a Linux user space application. Where I want to invoke registered callback function in user space area from the kernel space. Here the interrupt arriving on GPIO pin (For this event trigger I am using external button press) and registered function getting called in user space.
For your information I am using hardware is Jetson Xavier NX board running with linux OS (tegra-4.9) and GPIO9 AUDIO_MCLK connected to external switch (push button).
Is there any method is available to do this?
Thanks in advance for your response
Krrish
hello kannakishan37,
you could use this GitHub - NVIDIA/jetson-gpio: A Python library that enables the use of Jetson's GPIOs,
there’s sample, button_interrupt.py for your reference,
thanks
Hi JerryChang
Thanks for your response.
I am looking specially in c language.
Is there any reference code in C language.
check this discussion thread, Topic 144550, for several ways to access GPIOs. such as, kernel APIs, python scripts, C++ samples.
