i’m trying to install Nvidia driver for my Kali Linux machine, it was running well with the default nouveau driver.
After the installation, display resolution become very low. So I checked device status with lspci -s 26:00.0 –v And the output is like this
26:00.0 VGA compatible controller: NVIDIA Corporation TU106 [GeForce RTX 2060 Rev. A] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Device 7377:1501
Flags: bus master, fast devsel, latency 0, IRQ 10, IOMMU group 15
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel modules: nvidia
Kernel modules does show Nvidia, but the kernel driver in use is not shown.
I noticed that during boot up, there is an error of System[1]: Failed to start Load Kernel Modules So I checked with systemctl status systemd-modules-load.service command. The output shows nvidia-current and nvidia-current-modeset could not be found as following
Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static)
Active: failed (Result: exit-code) since Thu 2022-06-02 00:54:24 HKT; 7h left
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 446 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
Main PID: 446 (code=exited, status=1/FAILURE)
CPU: 10ms
Jun 02 00:54:24 kali systemd-modules-load[455]: modprobe: FATAL: Module nvidia-current not found in directory /lib/modules/5.15.0-kali3-amd64
Jun 02 00:54:24 kali systemd-modules-load[453]: modprobe: ERROR: ../libkmod/libkmod-module.c:990 command_do() Error running install command 'modprobe -i nvidia-current ' for module nvidia: retcode 1
Jun 02 00:54:24 kali systemd-modules-load[453]: modprobe: ERROR: could not insert 'nvidia': Invalid argument
Jun 02 00:54:24 kali systemd-modules-load[459]: modprobe: FATAL: Module nvidia-current-modeset not found in directory /lib/modules/5.15.0-kali3-amd64
Jun 02 00:54:24 kali systemd-modules-load[451]: modprobe: ERROR: ../libkmod/libkmod-module.c:990 command_do() Error running install command 'modprobe nvidia ; modprobe -i nvidia-current-modeset ' for module nvidia_modeset: retcode 1
Jun 02 00:54:24 kali systemd-modules-load[451]: modprobe: ERROR: could not insert 'nvidia_modeset': Invalid argument
Jun 02 00:54:24 kali systemd-modules-load[464]: modprobe: FATAL: Module nvidia-current-drm not found in directory /lib/modules/5.15.0-kali3-amd64
Notice: journal has been rotated since unit was started, output may be incomplete.
Here is the Nvidia related files under /lib/modules
./modules/5.15.0-kali3-amd64/kernel/drivers/usb/typec/altmodes/typec_nvidia.ko
./modules/5.15.0-kali3-amd64/kernel/drivers/net/ethernet/nvidia/forcedeth.ko
Besides purge all nvidia packages and re-install, I tried to add nouveau to the nvidia-blacklists-nouveau.conf, still the same result. I remember that I have successfully installed this driver once before (about 1-1.5 years ago), I am not sure what went wrong here, any advice is welcomed. Thanks.
GPU: RTX2060 CPU: R5-2600
