Release highlights since 530.30.02:
Added NV-CONTROL attributes
NV_CTRL_FRAMELOCK_MULTIPLY_DIVIDE_MODEandNV_CTRL_FRAMELOCK_MULTIPLY_DIVIDE_VALUEto allow syncing a Quadro Sync II card to different House Sync signal rates. This feature requires firmware version 2.18 or later; to download the latest firmware version, please visit: -
Fixed a bug that could cause the nvidia-settings control panel to crash when resetting the display layout.
Fixed a bug that could cause excessive GPU power consumption at idle when driving multiple displays with a high refresh rate.
Fixed a bug in nvidia-powerd which could cause excessive CPU usage.
Fixed an issue which could cause applications to run at 1 FPS when using an NVIDIA PRIME Display Offload sink as the only active display.
[README | Linux x86_64 | Solaris | FreeBSD x86_64 | Kernel driver source]
