Release highlights since 535.113.01:
Added experimental HDMI 10 bits per component support; enable by loading nvidia-modeset with
hdmi_deepcolor=1. -
Added support for the CTM, DEGAMMA_LUT, and GAMMA_LUT DRM-KMS CRTC properties. These are used by features such as the “Night Light” feature in GNOME and the “Night Color” feature in KDE, when they are used as Wayland compositors.
Added beta-quality support for GeForce and Workstation GPUs to open kernel modules. Please see the “Open Linux Kernel Modules” chapter in the README for details.
Added initial experimental support for runtime D3 (RTD3) power management on Desktop GPUs. Please see the ‘PCI-Express Runtime D3 (RTD3) Power Management’ chapter in the README for more details.
Added support for the EGL_ANDROID_native_fence_sync EGL extension and the VK_EXTERNAL_SEMAPHORE_HANDLE_TYPE_SYNC_FD_BIT and VK_EXTERNAL_FENCE_HANDLE_TYPE_SYNC_FD_BIT Vulkan external handle types when the nvidia-drm kernel module is loaded with the modeset=1 parameter.
Added experimental support for framebuffer consoles provided by nvidia-drm. On kernels that implement drm_fbdev_generic_setup and drm_aperture_remove_conflicting_pci_framebuffers, nvidia-drm will install a framebuffer console when loaded with both
modeset=1andfbdev=1kernel module parameters. This will replace the Linux boot console driven by a system framebuffer driver such as efifb or vesafb.Note that when an nvidia-drm framebuffer console is enabled, unloading nvidia-drm will cause the screen to turn off.
Updated nvidia-installer to allow installing the driver while an existing NVIDIA driver is already loaded.
Added support for virtual reality displays, such as the SteamVR platform, on Wayland compositors that support DRM leasing. Support requires xwayland version 22.1.0 and wayland-protocols version 1.22, or later. Tested on sway, minimum version 1.7 with wlroots version 0.15, and also on Kwin, minimum version 5.24.
Note: Before xwayland 23.2, there is a known issue with HDMI displays where the headset will fail to start a second time after closing SteamVR. This can be worked around by unplugging and replugging in the headset.
Fixed a bug that prevented VRR (Variable Refresh Rate) from working with Wayland.
Added support to the NVIDIA VDPAU driver for running in Xwayland. Please refer to the “Xwayland support in VDPAU” section of the README for further details.
Added libnvidia-gpucomp.so to the driver package. This is a helper library used for GPU shader compilation.
Removed libnvidia-vulkan-producer.so from the driver package. This helper library is no longer needed by the Wayland WSI.
Fixed a bug that intermittently caused the display to freeze when resuming from suspend on some Ada GPUs.
Fixed a bug that could cause monitors to flicker when the performance state changes on Turing GPUs.
[README | Linux x86_64 | Solaris | FreeBSD x86_64 | Kernel driver source]
