Release highlights since 510.68.02:
Published the source code to a variant of the NVIDIA Linux kernel modules dual-licensed as MIT/GPLv2. The source is available here:
GitHub - NVIDIA/open-gpu-kernel-modules: NVIDIA Linux open GPU kernel module source
and will be updated each driver release. Please see the “Open Linux Kernel Modules” chapter in the README for details. -
Added support for the following GPUs:
- RTX A2000 12GB
- RTX A4500
- T400 4GB
- T1000 8GB
Added support for the VK_EXT_external_memory_dma_buf and VK_EXT_image_drm_format_modifier Vulkan extensions. To use this functionality, the nvidia-drm kernel module must be loaded with DRM KMS mode setting enabled. See the DRM KMS section of the README for guidance on enabling mode setting.
Changed nvidia-suspend.service, nvidia-resume.service, and nvidia-hibernate.service to use WantedBy= rather than RequiredBy= dependencies for systemd-suspend.service and systemd-hibernate.service. This avoids a problem where suspend or hibernate fails if the NVIDIA driver is uninstalled without disabling these services first.
See systemd-logind croaks if suspend.target fails · Issue #21991 · systemd/systemd · GitHub
If these services were manually enabled, it may be necessary to update their dependencies by running
sudo systemctl reenable nvidia-suspend.service nvidia-resume.service nvidia-hibernate.service
Interlaced modes are now disabled when active stereo is enabled.
NVIDIA X Server Settings will now display the quit confirmation dialog automatically if only there are pending changes that need to be manually saved. The corresponding configuration option to control the appearance of the quit dialog was thus also removed.
Removed the warning message about mismatches between the compiler used to build the Linux kernel and the compiler used to build the NVIDIA kernel modules from nvidia-installer. Modern compilers are less likely to cause problems when this type of mismatch occurs, and it has become common in many distributions to build the Linux kernel with a different compiler than the default system compiler.
Updated nvidia-installer to skip test-loading the kernel modules on systems where no supported NVIDIA GPUs are detected.
Updated nvidia-installer to avoid a race condition which could cause the kernel module test load to fail due to udev automatically loading kernel modules left over from an existing NVIDIA driver installation. This failure resulted in an installation error message “Kernel module load error: File exists”.
Updated the RTD3 Video Memory Utilization Threshold (NVreg_DynamicPowerManagementVideoMemoryThreshold) maximum value from 200 MB to 1024 MB.
[README | Linux x86_64 | Solaris | FreeBSD x86_64 | Kernel driver source]
