Release highlights since 545.29.06:
Fixed an issue that sometimes caused Wayland applications to run at less than one frame per second on Maxwell, Volta, and Pascal series GPUs.
Fixed a bug that caused an intermittent drop in desktop framerate.
Fixed a bug that caused “Flip event timeout” messages to be printed to the system log when displays are hotplugged when nvidia-drm is loaded with the
fbdev=1kernel module parameter. -
Fixed intermittent Xid errors on Horizon Zero Dawn, Metro Exodus, Forza Horizon 5, and Halo Infinite.
Fixed a bug which prevented the “NoMaxPClkCheck” mode validation token from working on single-link TMDS (e.g. DVI, HDMI) outputs.
Fixed a bug that allowed VRR displays to be driven below their minimum refresh rate, resulting in a blank or flickering image.
Added an application profile to improve Kwin performance on hybrid GPU systems by setting
OGL_DEDICATED_HW_STATE_PER_CONTEXT=ENABLE_ROBUST. -
Updated the build process for NVIDIA kernel modules to honor the
INSTALL_MOD_DIRKbuild environment variable. -
Added support for R8, GR88 and YCbCr GBM formats.
Optimized the X driver headless framerate limiter to more closely mimic upstream behavior and prevent it from activating in inconvenient situations. Added a new X config option
LimitFrameRateWhenHeadlessto disable the headless framerate limiter. -
Fixed a bug that prevented Gamescope from running when using the NVIDIA Open GPU Kernel modules.
Fixed a bug that prevented the installer package from being unpacked on systems where zstd is not installed, when /tmp is mounted noexec.
Use transparent huge pages when available for the .text section. This is done through
madvise()calls, and requiresCONFIG_READ_ONLY_THP_FOR_FS. -
Changed the name visible in /proc/devices of NVIDIA devices and the NVIDIA control device from “nvidia-frontend” to “nvidia” and “nvidiactl”. Scripts which parse /proc/devices (such as udev rules) may need to be updated. Note that the conventional /dev device paths like /dev/nvidia0 and /dev/nvidiactl remain unchanged.
Fixed a bug that could cause some multi-GPU systems to crash on suspend.
Fixed a bug that could cause the system to crash when an application is run with
__NV_PRIME_RENDER_OFFLOAD=1. -
Fixed a bug which prevented application profiles from getting applied to PRIME Render Offloaded applications running via Wine.
Disabled PRIME Display Offload Sink support for virtual displays on datacenter GPUs. This prevents unusable desktop layouts from getting automatically configured on systems with a mix of physical and virtual displays.
Fixed a bug that caused high CPU usage during system suspend, which could lead to the system not entering s2idle in some cases.
Fixed a bug that caused the nvidia-settings control panel to crash when running on Wayland with newer versions of libwayland-client.
[README | Linux x86_64 | Solaris | FreeBSD x86_64 | Kernel driver source]
