Linux, Solaris, and FreeBSD driver 530.30.02 [beta]
Release highlights since 525.89.02:
  • Added an application profile to avoid performance problems in Xfce 4 when the OpenGL compositor backend is enabled along with G-SYNC.
  • Added support for suspend and resume when using GSP firmware.
  • Moved the nvidia-settings application icon into the ‘hicolor’ icon theme, which allows it to be customized by other icon themes selected in the desktop environment.
  • Fixed a bug that prevented PRIME render offload from working for Wayland applications when running on a system with an AMD iGPU.
  • Fixed a bug that prevented nvidia-installer from recording kernel log output to the installer log in some module loading failure paths.
  • Changed nvidia-installer to no longer use the $XDG_DATA_DIRS environment variable. XDG data files are now installed to a path specified by the --xdg-data-dir option, or /usr/share if not specified. This fixes a problem when Flatpak is installed that caused the installer to place the nvidia-settings.desktop file in /root/.local/share/flatpak/exports/share/applications.
  • Changed the behavior of glXGetRefreshRateSGI() for non-integer refresh rates to round to the nearest whole number rather than truncating.
  • Changed the compression format of the .run installer package from xz to zstd. This results in a smaller compressed package, and faster decompression performance. A fallback zstd decompressor is embedded into the installer package for systems which do not already have a zstd decompression program installed.
  • Fixed a bug that caused nvidia-installer to mistakenly unload some already loaded non-NVIDIA kernel modules.
  • Added compatibility for Linux kernels with Indirect Branch Tracking (IBT).
[README | Linux x86_64 | Solaris | FreeBSD x86_64 | Kernel driver source]
