I have following setup: Two monitors, the second output is split using a DVI to DVI+HDMI splitter to feed HDMI input of my TV set. All works fine if the TV is not turned on when X is started. But if the TV is on then my secondary display defaults to 800x600 instead of 1680x1050. So to work around of this problem I’m trying to load EDID from a file, I have following in my Monitor section:
Option “CustomEDID” “DFP-1:/etc/X11/Dell_edid.bin”
However, this file is not loaded. What am I doing wrong?
Gentoo kernel 3.10.7, GeForce 9500 GT, nvidia-drivers-3.25.15.
