我该怎么知道图中的报错是什么意思,是否有文档可以查询
Which Jetson platform?
Which JetPack SW?
How it’s reproduced?
你好,kayccc,这是Jetson Orin Nano Board,SDK是35.3.1,出现报错的原因是解串器有数据输出,但是使用v4l2-ctl -V --set-fmt-video=width=1920,height=1080,pixelformat=YUYV --set-ctrl bypass_mode=0,sensor_mode=0 --stream-mmap -d /dev/video0 点亮sensor时出现报错
cat /sys/kernel/debug/tracing/trace就出现上面的报错,我想知道报错的含义,然后解决问题
there’re several PHY interrupts,
for example,
0x08000000
shows the DPHY deskew calibration not complete on clock lane, this happened when the calibration sequence length is not long enough.0x10000000
shows the error is detected in the PHY partition [A/B] that some lanes detected sync words while other lanes not.0x40
and0x44
indicate there’re more than one bit error has detected on data-lane;
it’s more like an issue from hardware side, please review your sensor configurations.
thanks
thanks
