Couldn’t receive camera data in CPHY mode.
There is an error. What’s the meaning of status:0x00000040?
kworker/4:4-505 [004] … 3574.748655: rtcpu_nvcsi_intr: tstamp:112448461987 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
kworker/4:4-505 [004] … 3574.804647: rtcpu_nvcsi_intr: tstamp:112449478555 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
kworker/4:4-505 [004] … 3574.804649: rtcpu_nvcsi_intr: tstamp:112449540468 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
kworker/4:4-505 [004] … 3574.804649: rtcpu_nvcsi_intr: tstamp:112450819592 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000040
For the camera basic functionality first needs to check the device and driver configuration.
You can reference to below program guide for the detailed information of device tree and driver implementation.
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/CameraDevelopment/SensorSoftwareDriverProgramming.html?highlight=programing#sensor-software-driver-programming
Please refer to Applications Using V4L2 IOCTL Directly by using V4L2 IOCTL to verify basic camera functionality.
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/CameraDevelopment/SensorSoftwareDriverProgramming.html?highlight=programing#to-run-a-v4l2-ctl-test
Once confirm the configure and still failed below link help to get log and some information and some tips for debug.
https://elinux.org/Jetson/l4t/Camera_BringUp#Steps_to_enable_more_debug_messages
I want to know the meaning of status:0x00000040.
I have run the following commands to trace.
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
The camera configuration is
root@yt12-desktop:/home/yt12# v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'RG12' (12-bit Bayer RGRG/GBGB)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
root@yt12-desktop:/home/yt12# media-ctl -p -d /dev/media0
Media controller API version 5.10.120
Media device information
driver tegra-camrtc-ca
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 5.10.120
Device topology
entity 1: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
← “as_test 2-0010”:0 [ENABLED]
pad1: Source
→ “vi-output, as_test 2-0010”:0 [ENABLED] -
entity 4: as_test 2-0010 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev1
pad0: Source
[fmt:SRGGB12_1X12/1920x1080 field:none colorspace:srgb]
→ “13e40000.host1x:nvcsi@15a00000-”:0 [ENABLED] -
entity 6: vi-output, as_test 2-0010 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
← “13e40000.host1x:nvcsi@15a00000-”:1 [ENABLED]
I use 3 lanes in CPHY mode.
The DTS is:
i2c@3180000 {
#address-cells = <0x01>;
#size-cells = <0x00>;
iommus = <0x03 0x04>;
dma-coherent;
compatible = “nvidia,tegra234-i2c”;
reg = <0x00 0x3180000 0x00 0x100>;
nvidia,hw-instance-id = <0x02>;
interrupts = <0x00 0x1b 0x04>;
scl-gpio = <0x04 0x72 0x00>;
sda-gpio = <0x04 0x73 0x00>;
status = “okay”;
clock-frequency = <0x61a80>;
clocks = <0x02 0x32 0x02 0x66>;
clock-names = “div-clk\0parent”;
assigned-clocks = <0x02 0x32>;
assigned-clock-parents = <0x02 0x66>;
resets = <0x02 0x1e>;
reset-names = “i2c”;
dmas = <0x05 0x17 0x05 0x17>;
dma-names = “rx\0tx”;
nvidia,epl-reporter-id = <0x8052>;
phandle = <0x305>;
raw_1@10 {
compatible = "sensing,test";
reg = <0x10>;
devnode = "video0";
physical_w = "3.680";
physical_h = "2.760";
sensor_model = "imx390";
use_sensor_mode_id = "true";
reset-gpios = <0x04 0x3b 0x00>;
pwdn-gpios = <0x04 0xa0 0x00>;
pwr-gpios = <0x04 0xa7 0x00>;
phandle = <0x664>;
mode0 {
vc_id = [30 00];
mclk_khz = "24000";
num_lanes = [33 00];
phy_mode = "CPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = [30 00];
lane_polarity = [30 00];
active_w = "1920";
active_h = "1080";
mode_type = "bayer";
pixel_phase = "rggb";
csi_pixel_bit_depth = "12";
dynamic_pixel_bit_depth = "12";
readout_orientation = [30 00];
line_length = "2200";
inherent_gain = [31 00];
mclk_multiplier = "6.1875";
pix_clk_hz = "148500000";
serdes_pix_clk_hz = "833333333";
gain_factor = "10";
min_gain_val = [30 00];
max_gain_val = "300";
step_gain_val = [33 00];
default_gain = [30 00];
min_hdr_ratio = [31 00];
max_hdr_ratio = [31 00];
framerate_factor = "1000000";
min_framerate = "30000000";
max_framerate = "30000000";
step_framerate = [31 00];
default_framerate = "30000000";
exposure_factor = "1000000";
min_exp_time = "59";
max_exp_time = "33333";
step_exp_time = [31 00];
default_exp_time = "33333";
embedded_metadata_height = [30 00];
ports {
port@0 {
reg = <0x00>;
endpoint {
vc_id = <0x00>;
port-index = <0x00>;
bus-width = <0x03>;
remote-endpoint = <0x0b>;
phandle = <0x31d>;
nvcsi@15a00000 {
compatible = "nvidia,tegra194-nvcsi";
clocks = <0x02 0x51>;
clock-names = "nvcsi";
status = "okay";
num-channels = <0x02>;
num-tpg-channels = <0x24>;
phandle = <0x4c6>;
channel@0 {
reg = <0x00>;
status = "okay";
phandle = <0x4c7>;
ports {
port@0 {
reg = <0x00>;
status = "okay";
phandle = <0x4c8>;
endpoint@0 {
bus-width = <0x03>;
remote-endpoint = <0x31d>;
status = "okay";
phandle = <0x0b>;
port@1 {
reg = <0x01>;
status = "okay";
phandle = <0x4c9>;
endpoint@1 {
remote-endpoint = <0x2b4>;
status = "okay";
phandle = <0x26d>;
tegra-capture-vi {
compatible = “nvidia,tegra-camrtc-capture-vi”;
nvidia,vi-devices = <0x26a 0x26c>;
nvidia,vi-mapping-size = <0x06>;
nvidia,vi-mapping = <0x00 0x00 0x01 0x00 0x02 0x01 0x03 0x01 0x04 0x00 0x05 0x01>;
nvidia,vi-mapping-names = “csi-stream-id\0vi-unit-id”;
nvidia,vi-max-channels = <0x48>;
phandle = <0x49d>;
ports {
port@0 {
reg = <0x00>;
status = "okay";
phandle = <0x49e>;
endpoint {
vc-id = <0x00>;
bus-width = <0x03>;
remote-endpoint = <0x26d>;
status = "okay";
phandle = <0x2b4>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <0x03>;
max_lane_speed = <0x16e360>;
min_bits_per_pixel = <0x0a>;
vi_peak_byte_per_pixel = <0x02>;
vi_bw_margin_pct = <0x19>;
isp_peak_byte_per_pixel = <0x05>;
isp_bw_margin_pct = <0x19>;
max_pixel_rate = <0xb71b0>;
tpg_max_iso = <0x3bc400>;
phandle = <0x53b>;
modules {
module0 {
badge = "raw_1_bottom_A6V26";
position = "bottom";
orientation = [31 00];
status = "okay";
phandle = <0x53c>;
drivernode0 {
pcl_id = "v4l2_sensor";
devname = "raw_1 30-0010";
proc-device-tree = "/proc/device-tree/i2c@3180000/raw_1@10";
status = "okay";
phandle = <0x53d>;
drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/lens_imx274@A6V26/";
status = "okay";
phandle = <0x53e>;
The log tell SOT(Start Of Transfer) error. That could be the timing issue.
AGX use the Camera Connector interface.
I get the Jetson-AGX-Orin-Module-Carrier-Board-Specification_SP-10900-001_v1.2.pdf from Jetson Download Center | NVIDIA Developer
In the file there is only pin description.
Do you know how to connect pins in cphy mode?Do you know if AGX supports 3 lanes?
You can check the camera design guide.
Yes, CPHY 3 lanes configuration is supported.
Do you know which pins are included in serial_a interface in CPHY 3 lanes configuration.
Perhaps CSI0_D0_P,CSI0_D0_N,CSI0_CLK_P,CSI0_CLK_N,CSI0_D1_P,CSI0_D1_N,CSI1_D0_P,CSI1_D0_N,CSI1_CLK_P,CSI1_CLK_N are included in serial_a interface in CPHY 3 lanes configuration. I am not sure.
I don’t find the definiton. Could you please share the link?
Right, it’s serial_a for CSI0 and the bus-width is 3 for 3 lanes.
- You can check the REG NVCSI_PHY_0_CILA_INTR_0_STATUS_CILA_0 in TRM download from download center.
- Should be the same with 4 lanes configuration but don’t connect last like CSI0-CSI3 for 4 lanes then CSI0-CSI2 for 3 lanes.
