Hardware Platform: DRIVE AGX Xavier™ Developer Kit
Software Version: DRIVE Software 10
Running on the platform
Host Machine Version: Ubuntu 18.04
I have successfully perform extrinsic calibration using the Graph calibration tool. I have also run the Calibrated Graph to rig tool and generated a rig.json file.
The Graph calibration tool outputs the following type of information for the different external images and cameras involved in the calibration (have attached sample output below)
[30-09-2020 15:51:23] Saved calibrated graph to ./calibrated-graph.json
[30-09-2020 15:51:23] Writing validation images
Errors for intrinsics external-IMG_0924.JPG: Median=0.404315, mean=0.395903, var=0.0367015, std dev=0.191576, sample count=32, min=0.0935775, max=0.952394
Errors for intrinsics external-IMG_0924.JPG: Median=0.777376, mean=0.759124, var=0.061046, std dev=0.247075, sample count=140, min=0.153108, max=1.45862
Q1: Are there any options (command line options with ./calibration-graph-cli (or) ./calibration-graph-to-rig) which allows me to log all the reprojection error information (in say a .json file) for different cameras and externals images?
Notes: I have analyzed the different artefacts from the calibration process and I don’t seem to see the reprojection error being logged anywhere (except the command line when I run the tool obv.)
Q2: Other than the validation images generated is there any other ways to validate the extrinsics in Driveworks (like the intrinsics validator tool)?
Thanks in advance!
