At request of @dustinkerstein I’m posting my code implementing long exposure for IMX477 camera regarding to topic: Long exposure time because it has been closed. I’m posting it on new topic to make it accessible by other developers and reopen discussion about increasing of exposure time.
Below there are patches for kernel and gstnvarguscamera sources. Patches are for JetPack 4.5.1 with applied this patch first: NVIDIA-Jetson-IMX477-RPIV3/patches_nano at jetpack-4.5 · RidgeRun/NVIDIA-Jetson-IMX477-RPIV3 · GitHub.
Long exposure kernel patch:
diff --color -ruN kernel_org/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-camera-rbpcv3-dual-imx477.dtsi kernel_new/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-camera-rbpcv3-dual-imx477.dtsi
--- kernel_org/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-camera-rbpcv3-dual-imx477.dtsi 2021-10-15 11:12:14.832714213 +0200
+++ kernel_new/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-camera-rbpcv3-dual-imx477.dtsi 2021-10-15 10:53:54.968209251 +0200
@@ -221,12 +221,12 @@
default_gain = "16"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
- min_framerate = "2000000"; /* 2.0 fps */
+ min_framerate = "20000"; /* 0.02 fps */
max_framerate = "30000000"; /* 30.0 fps */
step_framerate = "1";
default_framerate = "30000000"; /* 30.0 fps */
min_exp_time = "11"; /* us */
- max_exp_time = "500000"; /* us */
+ max_exp_time = "50000000"; /* us */
step_exp_time = "1";
default_exp_time = "2495"; /* us */
@@ -261,12 +261,12 @@
+ min_framerate = "20000"; /* 2.0 fps */
max_framerate = "60000000"; /* 60.0 fps */
default_framerate = "60000000"; /* 60.0 fps */
diff --color -ruN kernel_org/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-camera-rbpcv3-imx477.dtsi kernel_new/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-camera-rbpcv3-imx477.dtsi
--- kernel_org/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-camera-rbpcv3-imx477.dtsi 2021-10-15 11:12:14.832714213 +0200
+++ kernel_new/hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-camera-rbpcv3-imx477.dtsi 2021-10-15 10:53:54.968209251 +0200
@@ -190,12 +190,12 @@
@@ -230,12 +230,12 @@
diff --color -ruN kernel_org/kernel/nvidia/drivers/media/i2c/imx477.c kernel_new/kernel/nvidia/drivers/media/i2c/imx477.c
--- kernel_org/kernel/nvidia/drivers/media/i2c/imx477.c 2021-10-15 11:12:14.832714213 +0200
+++ kernel_new/kernel/nvidia/drivers/media/i2c/imx477.c 2021-10-15 10:52:21.150927499 +0200
@@ -55,6 +55,7 @@
u32 frame_length;
struct camera_common_data *s_data;
struct tegracam_device *tc_dev;
+ u8 long_exp_shift;
static const struct regmap_config sensor_regmap_config = {
@@ -221,6 +222,7 @@
imx477_reg fl_regs[2];
u32 frame_length;
int i;
+ u8 long_exp_shift = 0;
dev_dbg(dev, "%s: Setting framerate control to: %lld\n", __func__, val);
@@ -228,14 +230,21 @@
(u64) mode->control_properties.framerate_factor /
mode->image_properties.line_length / val);
+ while ( frame_length > IMX477_MAX_FRAME_LENGTH &&
+ long_exp_shift < IMX477_MAX_LONG_EXP_SHIFT ) {
+ long_exp_shift++;
+ frame_length >>= 1;
if (frame_length < IMX477_MIN_FRAME_LENGTH)
frame_length = IMX477_MIN_FRAME_LENGTH;
else if (frame_length > IMX477_MAX_FRAME_LENGTH)
frame_length = IMX477_MAX_FRAME_LENGTH;
dev_dbg(dev,
- "%s: val: %llde-6 [fps], frame_length: %u [lines]\n",
- __func__, val, frame_length);
+ "%s: val: %llde-6 [fps], frame_length: %u [lines], long_exp_shift: %u\n",
+ __func__, val, frame_length, long_exp_shift);
imx477_get_frame_length_regs(fl_regs, frame_length);
for (i = 0; i < 2; i++) {
@@ -247,7 +256,15 @@
+ err = imx477_write_reg(s_data, IMX477_LONG_EXP_SHIFT_ADDR, long_exp_shift);
+ if (err) {
+ dev_err(dev,
+ "%s: frame_length control error: failed to write long exp shift\n", __func__);
+ return err;
priv->frame_length = frame_length;
+ priv->long_exp_shift = long_exp_shift;
return err;
@@ -268,8 +285,8 @@
u32 int_factor = val * mode->signal_properties.pixel_clock.val /
mode->control_properties.exposure_factor;
- coarse_time = int_factor / mode->image_properties.line_length;
- fine_int_time = int_factor % mode->image_properties.line_length;
+ coarse_time = (int_factor / mode->image_properties.line_length) >> priv->long_exp_shift;
+ fine_int_time = (int_factor % mode->image_properties.line_length) >> priv->long_exp_shift;
dev_dbg(dev, "%s: Setting exposure control to: %lld\n", __func__, val);
diff --color -ruN kernel_org/kernel/nvidia/include/media/imx477.h kernel_new/kernel/nvidia/include/media/imx477.h
--- kernel_org/kernel/nvidia/include/media/imx477.h 2021-10-15 10:55:53.709904180 +0200
+++ kernel_new/kernel/nvidia/include/media/imx477.h 2021-10-15 10:52:20.074912715 +0200
@@ -32,6 +32,7 @@
#define IMX477_MAX_COARSE_DIFF (10)
#define IMX477_MASK_LSB_2_BITS 0x0003
#define IMX477_MASK_LSB_8_BITS 0x00ff
+#define IMX477_MAX_LONG_EXP_SHIFT 7
/* imx477 sensor register address */
#define IMX477_MODEL_ID_ADDR_MSB 0x0000
@@ -47,5 +48,6 @@
#define IMX477_FINE_INTEG_TIME_ADDR_MSB 0x0200
#define IMX477_FINE_INTEG_TIME_ADDR_LSB 0x0201
#define IMX477_GROUP_HOLD_ADDR 0x0104
+#define IMX477_LONG_EXP_SHIFT_ADDR 0x3100
#endif /* __IMX477_H__ */
gstnvarguscamera patch:
diff --color -ruN gst-nvarguscamera_org/gstnvarguscamerasrc.cpp gst-nvarguscamera_new/gstnvarguscamerasrc.cpp
--- gst-nvarguscamera_org/gstnvarguscamerasrc.cpp 2021-10-15 11:35:58.428253998 +0200
+++ gst-nvarguscamera_new/gstnvarguscamerasrc.cpp 2021-10-15 11:38:48.434674148 +0200
@@ -70,18 +70,18 @@
#define MAX_BUFFERS 8
#define MIN_GAIN 1
-#define MAX_GAIN 16
+#define MAX_GAIN 22
#define MIN_EXPOSURE_TIME 34000
-#define MAX_EXPOSURE_TIME 358733000
+#define MAX_EXPOSURE_TIME 50000000000
#define MIN_DIGITAL_GAIN 1
#define MAX_DIGITAL_GAIN 256
#define GST_NVARGUS_MEMORY_TYPE "nvarguscam"
static const int DEFAULT_FPS = 30;
-static const uint64_t TIMEOUT_FIVE_SECONDS = 5000000000;
-static const uint64_t ACQUIRE_FRAME_TIMEOUT = 1000000000;
+static const uint64_t TIMEOUT_FIVE_SECONDS = 50000000000;
+static const uint64_t ACQUIRE_FRAME_TIMEOUT = 10000000000;
#ifdef __cplusplus
extern "C"
@@ -725,7 +725,7 @@
src->total_sensor_modes = modes.size();
GST_ARGUS_PRINT("Available Sensor modes :\n");
- frameRate = src->fps_n/ src->fps_d;
+ frameRate = src->fps_n/ static_cast<gfloat>(src->fps_d);
duration = 1e9 * src->fps_d/ src->fps_n;
ISensorMode *iSensorMode[modes.size()];
Range<float> sensorModeAnalogGainRange;
Binarne pliki gst-nvarguscamera_org/gstnvarguscamerasrc.o i gst-nvarguscamera_new/gstnvarguscamerasrc.o różnią się
Binarne pliki gst-nvarguscamera_org/gstnvarguscamera_utils.o i gst-nvarguscamera_new/gstnvarguscamera_utils.o różnią się
Binarne pliki gst-nvarguscamera_org/libgstnvarguscamerasrc.so i gst-nvarguscamera_new/libgstnvarguscamerasrc.so różnią się
diff --color -ruN gst-nvarguscamera_org/Makefile gst-nvarguscamera_new/Makefile
--- gst-nvarguscamera_org/Makefile 2021-10-15 11:35:58.428253998 +0200
+++ gst-nvarguscamera_new/Makefile 2021-10-15 11:35:58.656257113 +0200
@@ -49,6 +49,8 @@
OBJS := $(SRCS:.cpp=.o)
+CFLAGS += -DDEBUG -g
CFLAGS += -fPIC
CFLAGS += `pkg-config --cflags $(PKGS)`
I used below instruction to rebuild the kernel:
